How to change AP from Spectrum to Access Mode in Instant/AirWave
  • 1.  How to change AP from Spectrum to Access Mode in Instant/AirWave
    Posted Dec 14, 2016 11:35 AM
    I have an access point that somehow got into spectrum mode.  I don't seem to be able to change the AP back to access mode.
    I am attempting to do this by going into instant config in Airwave.> Go to Access Point > Select the access point that is in spectrum mode > click on the radio tab > change mode from spectrum to access > save and apply. I have also done this and rebooted the access point after.
    I can't get it to change roles.  Am I doing something wrong or am I having an issue with the AP and I need to completely reset it?
    Peter
  • 2.  RE: How to change AP from Spectrum to Access Mode in Instant/AirWave
    Posted Dec 16, 2016 07:16 AM
    Sounds like you're doing the right thing but it'snot working. I'd recommend calling TAC if you want to investigate.
    Cheers
    James
