How to change Internal Acknowlege splash page to HTTP
  • 1.  How to change Internal Acknowlege splash page to HTTP
    Posted Dec 02, 2016 11:51 AM
    I found out that there is an issue with the cert that that aruba uses for the internal acknowledge splash page.  I have a Instant 205 that is strictly for a guest network. Is there a way to change the splash page to use HTTP instead of HTTPS so that I don't have to upload my own cert?
    Mark
  • 2.  RE: How to change Internal Acknowlege splash page to HTTP
  • 3.  RE: How to change Internal Acknowlege splash page to HTTP
    Posted Aug 28, 2017 04:17 PM
    I dont want to use an ssl acknowledge page. How do I dislable ssl or enable http ?
