how to change IP of Instant93
  • 1.  how to change IP of Instant93
    Posted Sep 19, 2012 10:42 PM
    I try changing the IP adress of my Instant93 through CLI.  I telnet to the ap and send the following commands
    config
    setenv ipaddr 10.0.1.255
    exit wr mem
    exit
    But it does not work.Is there any suggestion?
    Thank you guys so much
  • 2.  RE: how to change IP of Instant93
    Posted Sep 20, 2012 01:28 AM
    You are in the bootloader which is way before the IAP SW loads.
    Configuration in Instant is intened to be done via the WebUI.  To change the IP address of the Instant VC in the WebUI go to Settings > General > Virtual Controller IP.
    You can also go in via the console port or Telnet after enabling "Terminal Access" and set the VC IP using the CLI command "virtual-controller-ip <addr>
  • 3.  RE: how to change IP of Instant93
    Posted Sep 20, 2012 05:43 PM
    The virtual IP address is assign to the Instant Cluster. The IP address will be active on the Virtual Controller.
    If you want to change the IP address on a specific IAP.
    1. Select the IAP -> Click on Edit -> Click on "Specify Statically" then fill in the IP Address, Subnet , Gateway, DNS in the text box
    2. Reboot the IAP
  • 4.  RE: how to change IP of Instant93
    Posted Sep 23, 2012 10:28 PM
    Yes, this is what I want to change. But I need to change it through CLI. Is there any way to do it?
  • 5.  RE: how to change IP of Instant93
    Posted Sep 23, 2012 10:27 PM
    Thanks for your reply. Marcus. But what I want to change is the master address. Is there any suggestion
  • 6.  RE: how to change IP of Instant93
    Posted Sep 23, 2012 11:21 PM
    In Instant Virtual Controller (VC) = Master.  I listed the syntax to change the VC IP in my first post. By hard-setting this address whomever is acting to the VC will respond on that IP.
    The CLI is not officially supported in Instant and there is no published CLI reference guide.  The WebUI is the best way.
  • 7.  RE: how to change IP of Instant93
    Posted Sep 24, 2012 02:26 AM
    Thanks Marcus. It works!! Great!
    Another question: Is the net mask available to be changed through CLI?
  • 8.  RE: how to change IP of Instant93
    Posted Sep 24, 2012 12:00 PM
    All the configuration for the IAP should be done via the Web UI.
  • 9.  RE: how to change IP of Instant93
    Posted May 26, 2016 08:22 AM
    For changing the Instant Virtual controller IP, CLI,
    Try:
    - connect with ssh or console to AP
    - configure
    - virtual-controller-ip xxx.xxx.xxx.xxx
    - exit
    - wri mem
    Worked for me
  • 10.  RE: how to change IP of Instant93
    Posted May 30, 2014 10:32 AM
    <edit> old post
