how to change native vlan of IAP from aruba central
This thread has been viewed 21 times
  • 1.  how to change native vlan of IAP from aruba central
    Posted Dec 15, 2016 07:39 AM
    I'm managing my IAP from aruba central, I would like to change the native vlan of my IAPs to tag vlan 1 for another SSID.
    Someone knows how to do it?
    To explain what I want to do:
    Management Vlan : 100
    SSID1: vlan 110
    SSID2: Vlan 1
  • 2.  RE: how to change native vlan of IAP from aruba central
    Posted Dec 15, 2016 08:00 AM
    You can set the Management VLAN in central. head to Configuration-->Access Points. You will get a list of all connected IAP's. Select one by clicking on the pencil at the and of the row. You will get a configuration screen. Open the "Uplink" context. There you can set the management vlan:
    The configured Management VLAN will be send out tagged.
    BR
    Florian
  • 3.  RE: how to change native vlan of IAP from aruba central
    Posted Dec 15, 2016 09:47 AM
    First, thanks for your answer.
    I knew this feature, but if I well understood, management vlan is tagged and not untagged.
    Infact, I would like to change the native vlan and to have the management vlan untagged because on the switch port I have untagged vlan 100 (management vlan) and tagged vlan 1 and 110.
  • 4.  RE: how to change native vlan of IAP from aruba central
    Posted Dec 17, 2016 01:12 AM
    Hello.
    Based on my experience configuring IAPs and switches, the management VLAN is untagged (native for Cisco switches, PVID for most others).  The additional VLANs are tagged.
    On my switch (Aruba 2920), the ports for the IAPs are untagged for VLAN 10 (my management network) and tagged for VLAN 11 (internal/employee) and 13 (guest).
    In Aruba Central, I configured the VC (System/General) with the static IP address, mask, and gateway I wanted for the IAP, and VLAN 10 as the VC VLAN.  For each IAP, I have also set the VLAN to 10 for uplink management for each IAP.
    For each WLAN, I've set the VLAN to static, with VLAN 11 for employee and 13 for guest.  I could also use ClearPass or another RADIUS server to set the VLAN for the user, based on RADIUS response (Dynamic) or rules I create for the WLAN.
    But the short version is that the management VLAN is untagged, and any specific VLANs for ESSIDs will be tagged.
  • 5.  RE: how to change native vlan of IAP from aruba central
    Posted Dec 19, 2016 02:56 AM
    I tried it but whitout success.
    Switch port configuration:
    - VLAN 110 (management) untagged
    - VLAN 1 tagged
    IAP Configuration:
    - Uplink management VLAN : 110
    - SSID 1: vlan static 1
    After this configuration, my IAP can't access to its gateway anymore and clients of SSID 1 get an IP in vlan 110.
    Any idea? did I make mistake in my configuration?
    thanks
