How to change the calledstationid in IAP UI
  • 1.  How to change the calledstationid in IAP UI
    Posted May 04, 2016 10:23 AM
    I'm setting up Cucumber hotpspot on Aruba AP 225. IN one of the steps it is asked to change the  change the format of the calledstationid.
    From Cucumber..:
    In recent firmwares, you need to change the format of the calledstationid, commonly known as mac address.
    http://community.arubanetworks.com/t5/Controller-less-WLANs/Configurable-RADIUS-packet-format-11-in-IAP/ta-p/234110
    18:64:7x:cx:9x:1x (SSID Profile "cucumber") # auth-pkt-mac-format delimiter -
    18:64:7x:cx:9x:1x (SSID Profile "cucumber") # auth-pkt-mac-format upper-case delimiter -
    18:64:7x:cx:9x:1x # commit apply
    18:64:7x:cx:9x:1x # write mem
     In UI, iI'm not able to find this option.
    #AP225
  • 2.  RE: How to change the calledstationid in IAP UI
    Posted May 04, 2016 11:52 PM
    We can configure “mac-authentication-delimiter” and “mac-authentication-upper-case” on both WEBUI and CLI.
    But we can only configure “auth-pkt-mac-format { upper-case } { delimiter <delim> }” on CLI.
  • 3.  RE: How to change the calledstationid in IAP UI
    Posted May 05, 2016 12:48 AM
    Can you please point out where this options would be on UI.
    Model number: ARUBA AP225
  • 4.  RE: How to change the calledstationid in IAP UI
    Posted May 05, 2016 04:52 PM
    my apology but i communicated that this option would not be in UI:
    "can only configure “auth-pkt-mac-format { upper-case } { delimiter <delim> }” on CLI."
