How to change the radio mode of an AP-335 from AM to Access?
  • 1.  How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 06:10 AM
    Hello community,
    I have a new AP-335 connected to my 7010 controller (6.5.0.0, updated from 6.4.3.7). I put in in the same group as my AP-215. But the radio mode is now "AM" and not "Access". Where can I change this? The rf profiles for a and g radio are the default profiles.
     #show ap active
    Active AP Table
    Name            Group     IP Address      11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  Uptime  Outer IP
    aruba-test-335  ergoTEST  192.168.130.61  0            AM                   0            AM                   335      Ea     5m:26s  N/A
    aruba-test-215  ergoTEST  192.168.130.16  1            AP:HT:6/9/19         0            AP:VHT:52E/18/22     215      a      8m:48s  N/A
    Steffen
    #AP-300
  • 2.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 06:15 AM
    Run "show log system 100 | include aruba-test-335" to see what is going on.
  • 3.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 06:19 AM
    thanks for your quick reply, here is the log:
    Jun 28 11:57:56 :303022:  <WARN> |AP aruba-test-335@192.168.130.61 nanny|  Reboot Reason: AP rebooted Tue Jun 28 11:56:29 GMT 2016; SAPD: Rebooting after provisioning
    Jun 28 11:58:24  KERNEL(aruba-test-335@192.168.130.61): [   67.740724] asap_mod: asap_dpa.c:2449:remove_in_flow() Inbound flow 0x9000 is not inserted yet
    Jun 28 11:58:24  KERNEL(aruba-test-335@192.168.130.61): [   67.843947] asap_mod: asap_dpa.c:2943:remove_out_flow() Outbound flow 0x9000 is not inserted yet
    Jun 28 11:58:40  KERNEL(aruba-test-335@192.168.130.61): [   84.482690] asap_bond_active_change: Uplink interface changed to eth1
    Jun 28 11:58:54  KERNEL(aruba-test-335@192.168.130.61): [   97.794444] aruba_phy_ctrl: No ethernet interface is disabled
    Jun 28 11:58:54  KERNEL(aruba-test-335@192.168.130.61): [   97.794487] Resetting spectral chainmask to Rx chainmask
    Jun 28 11:58:54  KERNEL(aruba-test-335@192.168.130.61): [   97.805719] Resetting spectral chainmask to Rx chainmask
    Jun 28 12:00:44 :326085:  <WARN> |AP aruba-test-335@192.168.130.61 sapd|  AM: Setting collection of statistics to : enabled
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    0.000000]
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    0.000000] Aruba Networks
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    0.000000] ArubaOS Version 6.5.0.0 (build 55392 / label #55392)
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    0.000000] Built by p4build@chios on 2016-06-10 at 22:12:21 PDT (gcc version 4.8.1)
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    0.113560] QMAN at 400mHz
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    2.455532] mtdoops: mtd device (mtddev=name/number) must be supplied
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    2.634045] Aquantia Firmware version: 2.b
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    2.684889] FMAN at 600mHz
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    2.724205] Freescale FM module (Jun 11 2016:05:09:08), FMD API version 21.1.0
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    2.812115] Freescale FM Ports module (Jun 11 2016:05:09:08)
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    3.152427] fsl_oh dpa-fman0-oh.20: Allocating 0 ingress frame queues duples
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    3.237040] fsl_oh dpa-fman0-oh.21: Allocating 0 ingress frame queues duples
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    3.321596] fsl_oh dpa-fman0-oh.22: Allocating 0 ingress frame queues duples
    Jun 28 12:02:14  KERNEL(aruba-test-335@192.168.130.61): [    3.623739] PME2: fsl_pme2_db_init: not on ctrl-plane
    Jun 28 12:02:16 :303022:  <WARN> |AP aruba-test-335@192.168.130.61 nanny|  Reboot Reason: AP rebooted due to loss power
    Jun 28 12:02:44  KERNEL(aruba-test-335@192.168.130.61): [   66.471884] asap_mod: asap_dpa.c:2449:remove_in_flow() Inbound flow 0x9000 is not inserted yet
    Jun 28 12:02:44  KERNEL(aruba-test-335@192.168.130.61): [   66.575165] asap_mod: asap_dpa.c:2943:remove_out_flow() Outbound flow 0x9000 is not inserted yet
    Jun 28 12:03:13  KERNEL(aruba-test-335@192.168.130.61): [   96.482424] aruba_phy_ctrl: No ethernet interface is disabled
    Jun 28 12:03:13  KERNEL(aruba-test-335@192.168.130.61): [   96.482480] Resetting spectral chainmask to Rx chainmask
    Jun 28 12:03:13  KERNEL(aruba-test-335@192.168.130.61): [   96.493728] Resetting spectral chainmask to Rx chainmask
    Jun 28 12:05:08 :326085:  <WARN> |AP aruba-test-335@192.168.130.61 sapd|  AM: Setting collection of statistics to : enabled
  • 4.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 07:25 AM
    additional information: I now connected a AP-315 to the controller and I have the same problem, the new access point ist in air monitor mode:
    (ergo-WLAN-Aruba) #show ap active
    Active AP Table
    aruba-test-315       ergoTEST  192.168.130.62  0            AM                   0            AM                   315      a      7m:12s      N/A
    aruba-test-335       ergoTEST  192.168.130.61  0            AM                   0            AM                   335      Ea     1h:22m:36s  N/A
    aruba-test-215       ergoTEST  192.168.130.16  0            AP:HT:6/9/19         0            AP:VHT:52E/18/22     215      a      1h:29m:48s  N/A
    (ergo-WLAN-Aruba) #show log system 100 | include aruba-test-315
    Jun 28 13:18:10 :303022:  <WARN> |AP aruba-test-315@192.168.130.62 nanny|  Reboot Reason: AP rebooted Tue Jun 28 13:16:32 GMT 2016; SAPD: Rebooting after provisioning
    Jun 28 13:18:47  KERNEL(aruba-test-315@192.168.130.62): [  106.450640] Disabling USB power
    Jun 28 13:19:03  KERNEL(aruba-test-315@192.168.130.62): [  122.204154] Enabling USB power
    Jun 28 13:19:03  KERNEL(aruba-test-315@192.168.130.62): [  122.204154] Resetting spectral chainmask to Rx chainmask
    Jun 28 13:19:03  KERNEL(aruba-test-315@192.168.130.62): [  122.204279] Resetting spectral chainmask to Rx chainmask
    Jun 28 13:21:02 :326085:  <WARN> |AP aruba-test-315@192.168.130.62 sapd|  AM: Setting collection of statistics to : enabled
  • 5.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 08:31 AM
    What country are you in? Do a 'show ap allowed-channel country-code (your code) ap-type 335/315'
    (Aruba7005) #show ap allowed-channels country-code uS ap-type 335
    Allowed Channels for AP Type 335 Country Code "US" Country "United States"
    PHY Type                  Allowed Channels
    802.11g (indoor)          1 2 3 4 5 6 7 8 9 10 11
    802.11a (indoor)          36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165
    802.11g (outdoor)         1 2 3 4 5 6 7 8 9 10 11
    802.11a (outdoor)         36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165
    802.11g 40MHz (indoor)    1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (indoor)    36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 140-144 149-153 157-161
    802.11g 40MHz (outdoor)   1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (outdoor)   36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 140-144 149-153 157-161
    802.11a 80MHz (indoor)    36-48 52-64 100-112 116-128 132-144 149-161
    802.11a 80MHz (outdoor)   36-48 52-64 100-112 116-128 132-144 149-161
    802.11a 160MHz (indoor)   36-64 100-128
    802.11a 160MHz (outdoor)  36-64 100-128
    802.11a (DFS)             52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144
    (Aruba7005) #
  • 6.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 08:57 AM
    Oh. Okay. I'm in Germany, Country code "DE". I think there is the problem, allowed channels are all set to "None". But how can I change it? I cant find an option in the GUI.
    (ergo-WLAN-Aruba) #show ap allowed-channels country-code DE ap-type 335
    Allowed Channels for AP Type 335 Country Code "DE" Country "Germany"
    802.11g (indoor)          None
    802.11a (indoor)          None
    802.11g (outdoor)         None
    802.11a (outdoor)         None
    802.11g 40MHz (indoor)    None
    802.11a 40MHz (indoor)    None
    802.11g 40MHz (outdoor)   None
    802.11a 40MHz (outdoor)   None
    802.11a 80MHz (indoor)    None
    802.11a 80MHz (outdoor)   None
    802.11a 160MHz (indoor)   None
    802.11a 160MHz (outdoor)  None
    802.11a (DFS)             None
    (ergo-WLAN-Aruba) #show ap allowed-channels country-code DE ap-type 315
    Allowed Channels for AP Type 315 Country Code "DE" Country "Germany"
    802.11a (DFS)             None
  • 7.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 09:12 AM
    Looks like DE/Germany has not yet approved the 335 or 315 yet. I will check with PLM, but it might be a few more weeks. Keep an eye out for the DRT files on the support site as they will be updated as soon as Germany approves the 315/335, upon which you can download the latest DRT file which will enable the 315/335.
  • 8.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 09:33 AM
    Thank you for your reply,
    I will look in some days if there is an update available.
    Steffen
  • 9.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jun 28, 2016 12:51 PM
    That's correct. The current compliance status of the AP-31x and AP-33x is expected to be updated to include all EU countries "any day". Once that's in place, the next DRT release will reflect the change and enable these APs to be used in access mode in all EU countries.
  • 10.  RE: How to change the radio mode of an AP-335 from AM to Access?
    Posted Jul 19, 2016 03:05 AM
    I activated the new DRT file (DRT 1.0_55642) and now it works fine. Thank you.
