How to edit the roler for particular client in Aruba Networks Virtual Controller.
Here is a screenshot,
If you want to change the contents of the Role you can do this under the Security section:
https://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/Roles_and_policies/UserRole.htm
If you want a particular role to be assigned to a client, you can do this using role derivation.
https://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/Roles_and_policies/CreateRoleAssignment.htm
