Hi Marcel
Domain joins can be a challange if the Active Directory has been hardened. In your case it looks like either the account you try to do the test with isn't correct, or the host name isn't accepted for some reason. I don't think I have seen this error message.
If you try to join from the GUI, what message do you get?
As the initial issue in this thread is something else, maybe a new thread would be better.
Best Regards
Jonas Hammarbäck
Aranya AB
Original Message:
Sent: May 22, 2024 01:25 PM
Subject: How to check if ClearPass joined a domain
Hi Herman,
Known its a old topic but when de ad testjoin NL failed. How i have to interpreted this issue?
Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
Original Message:
Sent: Jun 01, 2018 03:19 AM
+1 on the ClearPass version. Make sure you are running up to date ClearPass software.
On the domain join check, you can do that on the CLI with the ad testjoin command:
[appadmin@cppm-nl]# ad testjoin NLJoin is OK
Where NL is the NETBIOS name of my domain.
