How to check If RAP turn on nat traversal ?
  • 1.  How to check If RAP turn on nat traversal ?
    Posted Jul 01, 2018 08:56 PM
    How to check If RAP turn on nat traversal ? We are do the followed network, and we input the show datapath session table | include 4500 get the followed information. are there anybody can tell us what'a meah FC FY ? and If we can khow the RAP tun on or off the NAT-N ? and how to know this ?
  • 2.  RE: How to check If RAP turn on nat traversal ?
    MVP EXPERT
    Posted Jul 02, 2018 01:46 AM
    A Y flag means that the 3 way hand shake is not occurring so the IPSEC tunnel isn’t established. Provision the RAP so that it is pointing to your 47.x.x.x address.
    Do you have UDP4500 permitted via all firewalls? Is this just affecting a single RAP or all RAPs?
  • 3.  RE: How to check If RAP turn on nat traversal ?
    Posted Jul 02, 2018 02:05 AM
    Dear Mr Zalion
    1. you can see all of the detail here
    http://community.arubanetworks.com/t5/Wireless-Access/Aruba-RAP-contact-to-public-IP-VMC-AOS8-3-problem-need-help/td-p/438204
    2. all of the rap same problem.
    3. we have open the udp 4500 and GRE protocol in all of the firewall we can controll.
    4.please check if you can access 47.104.193.111 by web or ssh, if yes, we can give you password to check them. This VMC is for test, So please do not worry about, you can do any change inside, because we can reset it to default in a few minitue
  • 4.  RE: How to check If RAP turn on nat traversal ?
    Posted Jul 02, 2018 03:43 AM
    If you see port 4500 used, the RAP is using NAT Traversal. As far as I know, RAPs always use NAT Traversal.
    If you see IKE (udp/500) and AH (ip proto 51) then there is no NAT-T.
    For RAP, just udp/4500 should be ok.
    Also in general, there are only few things that can go wrong with RAP. What I have seen: Firewalls that open the udp/4500 IPSec session (disable DPI on VPN traffic for your RAPs), RAP not whitelisted (show log system all returns authentication errors for the MAC of the RAP), no IP VPN pool (RAP should be able to get an IP), or authentication issues (rarely with TPM certificate authentication; more with PSK wrong passwords).
    Do you have access to an Aruba partner, and/or Aruba Support? Please work with them as interactive troubleshooting will likely get a result much faster than asking through this forum.
  • 5.  RE: How to check If RAP turn on nat traversal ?
    Posted Jul 02, 2018 03:50 AM
    Finially we found the way to test VMC and firewall,but we still do not know if RAP run at UDP 4500 ?
  • 6.  RE: How to check If RAP turn on nat traversal ?
    Posted Jul 02, 2018 04:08 AM
    (AOS83) [mynode] #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    Flags: 1 = 802.1x authenticated AP use EAP-PEAP; 1+ = 802.1x use EST; 1- = 802.1x use factory cert; 2 = Using IKE version 2
    (AOS83) [mynode] #show ap-group
    default
    NoAuthApGroup
    rap
    <profile-name> Profile name
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show ap-group rap
    AP group "rap"
    Parameter Value
    Virtual AP ArubaRAP
    802.11a radio profile default
    802.11g radio profile default
    Ethernet interface 0 port configuration default
    Ethernet interface 1 port configuration default
    Ethernet interface 2 port configuration shutdown
    Ethernet interface 3 port configuration shutdown
    Ethernet interface 4 port configuration shutdown
    AP system profile default
    AP multizone profile default
    802.11a Traffic Management profile N/A
    802.11g Traffic Management profile N/A
    Regulatory Domain profile default
    RF Optimization profile default
    RF Event Thresholds profile default
    IDS profile default
    Mesh Radio profile default
    Mesh Cluster profile N/A
    Provisioning profile N/A
    AP authorization profile N/A
    (AOS83) [mynode] #show wlan virtual-ap
    ArubaRAP
    default
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show wlan virtual-ap arubaRAP
    Virtual AP profile "ArubaRAP"
    Parameter Value
    AAA Profile ArubaRAP
    802.11K Profile default
    Hotspot 2.0 Profile N/A
    Virtual AP enable Enabled
    VLAN 1
    Forward mode tunnel
    SSID Profile ArubaRAP
    Allowed band all
    Band Steering Disabled
    Cellular handoff assist Disabled
    Openflow Enable Enabled
    Steering Mode prefer-5ghz
    Dynamic Multicast Optimization (DMO) Disabled
    Dynamic Multicast Optimization (DMO) Threshold 6
    Drop Broadcast and Multicast Disabled
    Convert Broadcast ARP requests to unicast Enabled
    Authentication Failure Blacklist Time 3600 sec
    Deny inter user traffic Disabled
    Deny time range N/A
    DoS Prevention Disabled
    HA Discovery on-association Enabled
    Mobile IP Enabled
    Preserve Client VLAN Disabled
    Remote-AP Operation standard
    Station Blacklisting Enabled
    Strict Compliance Disabled
    VLAN Mobility Disabled
    WAN Operation mode always
    FDB Update on Assoc Disabled
    WMM Traffic Management Profile N/A
    Anyspot profile N/A
    (AOS83) [mynode] #show aaa profile
    ArubaRAP
    default
    default-dot1x
    default-dot1x-psk
    default-iap-aaa-profile
    default-mac-auth
    default-open
    default-tunneled-user
    default-xml-api
    NoAuthAAAProfile
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show aaa profile arubaRAP
    AAA Profile "ArubaRAP"
    Parameter Value
    Initial role authenticated
    MAC Authentication Profile N/A
    MAC Authentication Default Role guest
    MAC Authentication Server Group default
    802.1X Authentication Profile N/A
    802.1X Authentication Default Role guest
    802.1X Authentication Server Group N/A
    Download Role from CPPM Disabled
    Set username from dhcp option 12 Disabled
    L2 Authentication Fail Through Disabled
    Multiple Server Accounting Disabled
    User idle timeout N/A
    Max IPv4 for wireless user 2
    RADIUS Accounting Server Group N/A
    RADIUS Roaming Accounting Disabled
    RADIUS Interim Accounting Disabled
    RADIUS Acct-Session-Id In Access-Request Disabled
    XML API server N/A
    RFC 3576 server N/A
    User derivation rules N/A
    Wired to Wireless Roaming Enabled
    Reauthenticate wired user on VLAN change Disabled
    Device Type Classification Enabled
    Enforce DHCP Disabled
    PAN Firewall Integration Disabled
    Open SSID radius accounting Disabled
    (AOS83) [mynode] #show wlan ssid-profile
    ArubaRAP
    default
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show wlan ssid-profile arubaRAP
    SSID Profile "ArubaRAP"
    Parameter Value
    SSID enable Enabled
    ESSID ArubaRAP
    WPA Passphrase N/A
    Encryption opensystem
    Enable Management Frame Protection Disabled
    Require Management Frame Protection Disabled
    DTIM Interval 1 beacon periods
    802.11a Basic Rates 6 12 24
    802.11a Transmit Rates 6 9 12 18 24 36 48 54
    802.11g Basic Rates 1 2
    802.11g Transmit Rates 1 2 5 6 9 11 12 18 24 36 48 54
    Station Ageout Time 1000 sec
    Max Transmit Attempts 8
    RTS Threshold 2333 bytes
    Short Preamble Enabled
    Max Associations 64
    Wireless Multimedia (WMM) Disabled
    Wireless Multimedia U-APSD (WMM-UAPSD) Powersave Enabled
    WMM TSPEC Min Inactivity Interval 0 msec
    DSCP mapping for WMM voice AC (0-63) N/A
    DSCP mapping for WMM video AC (0-63) N/A
    DSCP mapping for WMM best-effort AC (0-63) N/A
    DSCP mapping for WMM background AC (0-63) N/A
    WMM Access Class of EAP traffic default
    Multiple Tx Replay Counters Enabled
    Hide SSID Disabled
    Deny_Broadcast Probes Disabled
    Local Probe Request Threshold (dB) 0
    Auth Request Threshold (dB) 0
    Disable Probe Retry Enabled
    Battery Boost Disabled
    WEP Key 1 N/A
    WEP Key 2 N/A
    WEP Key 3 N/A
    WEP Key 4 N/A
    WEP Transmit Key Index 1
    WPA Hexkey N/A
    Maximum Transmit Failures 0
    EDCA Parameters Station profile N/A
    EDCA Parameters AP profile N/A
    BC/MC Rate Optimization Disabled
    Rate Optimization for delivering EAPOL frames Enabled
    Strict Spectralink Voice Protocol (SVP) Disabled
    High-throughput SSID Profile default
    802.11g Beacon Rate default
    802.11a Beacon Rate default
    Video Multicast Rate Optimization default
    Advertise QBSS Load IE Disabled
    Advertise Location Info Disabled
    Advertise AP Name Disabled
    Traffic steering from WLAN to cellular Disabled
    802.11r Profile N/A
    Enforce user vlan for open stations Disabled
    Enable OKC Enabled
    In Fact, we use the role logon frist, and change to authenticated, because we think if there are some limits for logon ?
    (AOS83) [mynode] #show rights authenticated
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'authenticated'
    Up BW:No Limit Down BW:No Limit
    L2TP Pool = rap_pool1
    PPTP Pool = default-pptp-pool
    Number of users referencing it = 0
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    Youtube education: Disabled
    Web Content Classification: Enabled
    IP-Classification Enforcement: Enabled
    ACL Number = 79/0
    Openflow: Enabled
    Max Sessions = 65535
    Check CP Profile for Accounting = TRUE
    Application Exception List
    Name Type
    Application BW-Contract List
    Name Type BW Contract Id Direction
    access-list List
    Position Name Type Location
    1 global-sacl session
    2 apprf-authenticated-sacl session
    3 ra-guard session
    4 allowall session
    5 v6-allowall session
    global-sacl
    Priority Source Destination Service Application Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan IPv4/6 Contract
    ra-guard
    1 user any icmpv6 rtr-adv deny Low 6
    allowall
    1 any any any permit Low 4
    2 any any any-v6 permit Low 6
    v6-allowall
