How to check the AP has built the tunnel to the Cluster controllers IN CLI
  • 1.  How to check the AP has built the tunnel to the Cluster controllers IN CLI
    Posted Jan 30, 2020 06:04 AM
    Hi Friends,
    How to check the AP has built the active and standby tunnel to the cluster controller using CLI command.
    Issue here is, I am seeing heartbeat miss between the controller and AP, the AP is rebootstraping.
    But the connectivity packet size allowed between AP and controller is 1250 mtu with all the APs but we have the issue with two perticular APs.
    Mallikarjun
  • 2.  RE: How to check the AP has built the tunnel to the Cluster controllers IN CLI
    Posted Jan 30, 2020 06:12 AM
    "show ap database" will let you know if a primary and secondary tunnel is built, but it will not be updated dynamically when there are heartbeat misses.
    What is the difference between those two APS and the others?
  • 3.  RE: How to check the AP has built the tunnel to the Cluster controllers IN CLI
    Posted Feb 04, 2020 09:40 AM
    Thank you
