How to check the content of the partition?
This thread has been viewed 70 times
  • 1.  How to check the content of the partition?
    Posted Dec 14, 2015 09:24 AM
    Hi guys,
    I want to check the storage-usage in the partition.
  • 2.  RE: How to check the content of the partition?
    Posted Dec 14, 2015 09:27 AM
    Partition 0 and 1 are for the firmware images. Partition 0:2 is the flash. You can check the storage details using "# show storage". To see the files in the flash, use "# dir".
    Rajaguru Vincent
  • 3.  RE: How to check the content of the partition?
    Posted Dec 14, 2015 08:32 PM
    Hi rvincent,
    (Master-Controller) #show storage
    Filesystem Size Used Available Use% Mounted on
    none 2.0G 21.3M 2.0G 1% /tmp
    /dev/usb/flash3 1.5G 111.0M 1.3G 8% /flash
    It didn't show the storage of the partition 0 and partition 1.
  • 4.  RE: How to check the content of the partition?
    Posted Dec 15, 2015 10:33 AM
    You have options to check the storage details or files stored in the flash by using "# show storage" and "# dir". There are no options to check the details for partition 0 and partition 1. They are used only for firmware images.
    But why would someone want to check the storage of partition 0 and 1. I don't think there would be any requirement for that.
    Rajaguru Vincent
  • 5.  RE: How to check the content of the partition?
    Posted Dec 15, 2015 11:23 AM
    You may have better luck with 'show image version'
    Default boot signifies which version you're running on boot-time
    (Aruba3600-117) #show image version
    Partition : 0:0 (/dev/hda1) **Default boot**
    Software Version : ArubaOS 6.3.0.0 (Digitally Signed - Production Build)
    Build number : 38241
    Label : 38241
    Built on : Thu May 2 20:40:35 PDT 2013
    Partition : 0:1 (/dev/hda2)
    Software Version : ArubaOS 6.3.1.0 (Digitally Signed - Production Build)
    Build number : 39611
    Label : 39611
    Built on : Tue Aug 27 08:26:28 PDT 2013
