SD-WAN
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
How to clear configuration failures
This thread has been viewed 22 times
  • 1.  How to clear configuration failures
    Posted Nov 29, 2021 11:40 AM
    Hi community
    I'm not sure if it is correct place to post such a topic, but my solution is based on Aruba SDWAN.
    I have quite often problem with configuration failure error, and I don't see how to resolve issue, I have huge problem to exit failure state it seem like I'm spinnng around.
    Is there any option to rollback or clear configuration which causes failure ?
    It would be nice clear/delete failure config but I don't see such a possibility at this moment.
    What is the best way to exit config failure state ??
    regards
    K
    Karol Karkowski
  • 2.  RE: How to clear configuration failures
    Posted Nov 29, 2021 05:45 PM
    Why is it failing is the most important point....
    If you want to just download the whole config again, you would execute "ccm-debug full-config-sync" on the MD.
  • 3.  RE: How to clear configuration failures
    Posted Nov 30, 2021 05:40 AM
    In my case I had to change DNS servers on 60 branch controllers.
    Now it seems ok, I had to make double restart of all controllers, restart seems to resolve the problem
    But failure description seemed have no sense, sometimes It is quite hard for typical/standard user to deal with failure state.
    It could be better way from Aruba to resolve such a situation
    Thanks for help
    Best regards
    Karol
    Karol Karkowski
