How to collect email addresses that were entered in Guest Captive Portal?
  • 1.  How to collect email addresses that were entered in Guest Captive Portal?
    Posted Mar 01, 2016 01:41 AM
    I had two Aruba IAP-105 and i'm using a Virtual Controller. I configured a guest access wifi which has Internal -  Acknowledged setup where the guest users will just enter their email addresses in able to be connected to the internet. I want to collect all those email addresses. Is there any way to do that without monitoring the GUI all the time. THanks.
  • 2.  RE: How to collect email addresses that were entered in Guest Captive Portal?
    Posted Mar 01, 2016 01:42 AM
    Are you using AirWave or Aruba Central?
    Sent from Nine
  • 3.  RE: How to collect email addresses that were entered in Guest Captive Portal?
    Posted Mar 01, 2016 01:46 AM
    I'm using aruba instant, virtual controller only... THanks.
