how to config IAP RAP3 work with 3g dongle ?
  • 1.  how to config IAP RAP3 work with 3g dongle ?
    Posted Mar 10, 2013 07:34 AM
    Hi all,
    I tried to test IAP RAP3 with 3g dongle (vofafone Huawei K4511) but no luck it doesn't work. it's alway showing "Linkdown"
    please see logs below.
    3/10/2013 18:24:11 PM    Target: 00:1a:1e:08:50:7f    Command: show cellular status *********************************************************************************************************
    cellular status
    card     detect     link
    Present  detect-ok  Linkdown
    USB Modem Information
    Parameter      Value
    Manufacturer    Vodafone
    Product         Vodafone
    Serial Number   Driver          (none)
    Vendor ID       12d1
    Product ID      14cc
    and this is my configuration
    cellular configure
    Type            Value
    4g-usb-type
    usb-type        option
    usb-dev         12d114cc
    usb-tty         ttyUSB0
    usb-init        AT+CGDCONT=1,"IP","internet"
    usb-user        web
    usb-passwd      web
    usb-dial        ATD*99#
    usb-modeswitch  -v 0x12d1 -p 0x14b7 -M 55534243123456780000000000000011062000000100000000000000000000
    modem-isp
    anyone can help?
    Thanks in advance
  • 2.  RE: how to config IAP RAP3 work with 3g dongle ?
    Posted Mar 10, 2013 07:55 AM
    Hi.
    Full instructions including supported modems can be found in the Instant 6.1.3.4-3.1.0.0 user guide.    It is in Chapter 24: Uplink Configuration.
    *ATTACHED TO THIS POST FOR YOU* (read chapter 24 very very good)
    Attachment(s)
  • 3.  RE: how to config IAP RAP3 work with 3g dongle ?
    Posted Mar 10, 2013 08:10 AM
    @aakmit wrote:
    Hi all,
    cellular status
    card     detect     link
    Parameter      Value
    Product         Vodafone
    Vendor ID       12d1
    Product ID      14cc
    cellular configure
    Type            Value
    4g-usb-type
    usb-type        option
    usb-dev         12d114cc
    usb-tty         ttyUSB0
    usb-user        web
    usb-passwd      web
    usb-dial        ATD*99#
    modem-isp
    anyone can help?
    Thanks in advance
    Please open a support case.  This modem is not on the list of tested/supported so it could require some custom parameters for the RAP3.
  • 4.  RE: how to config IAP RAP3 work with 3g dongle ?
    MVP GURU
    Posted Mar 10, 2013 06:17 PM
    I have already use this 3g key with RAP (RAP5) and ArubaOS 6.x and it works !
    My settings (for ArubaOS):
    • Device : Other (Any)
    • TTY Device Path : ttyUSB0
    • Initialization String : AT+CGDCONT=1,’IP’,’APN’
    • Device Identifier : 0x12d114cc
    • Device Type : option
    • Modeswitch : -v 12d1 -p 14b7 -M 55534243123456780000000000000011062000000100000000000000000000
    • Dial String : ATDT*99***1#
    • Link Priority Ethernet : 10
    Replace APN by your APN Provider
