how to config IAP wired port for client?
  • 1.  how to config IAP wired port for client?
    Posted Feb 24, 2013 11:25 AM
    Hi all,
    I setting up IAP to use 3g uplink with Employee SSID which work properly and I'd like to setup wired port for client but no luck wired client can't get ip address.
     anyone have a good configuration on IAP for wired port ?
    PS. ip address assigned by virtual controller
    thanks in advance.
  • 2.  RE: how to config IAP wired port for client?
    Posted Feb 24, 2013 12:55 PM
    Good evening,
    If you would like to Ethernet Downlink in Virtual AP (InstantAP/RAP) - Read the attached user (PDF) -guide from page 193.
    Let me know if - it's helped you. :smileyhappy:
    *MAKE SURE THAT U CHOOSE THE RIGHT CONFIG OF THE PORTS (TRUNK/ACCESS - VLANS - ACL - SECURITY)*
    If you have further question or more information needed - feel free to ask.
    Have a gr8 weekend. :smileyvery-happy:
    me
    Attachment(s)
  • 3.  RE: how to config IAP wired port for client?
    Posted Feb 24, 2013 01:16 PM
    hi kdisc98
    Thanks for your reply. But I tried to config following user guide step but wired client can't get ip address from IAP.
    my solution want to wired and wireless client getting ip address from IAP which IAP connected to 3G dongle as uplink.
    PS. It's seem like wired port don't support DHCP from virtual controller.
  • 4.  RE: how to config IAP wired port for client?
    Posted Feb 24, 2013 02:10 PM
    Thanks again. Now i can figure out which refer to this link.
    http://community.arubanetworks.com/t5/Aruba-Instant/Setup-for-Instant-as-the-DHCP-Server/td-p/59318
    thanks a lot.
  • 5.  RE: how to config IAP wired port for client?
    Posted Feb 24, 2013 02:11 PM
    Ok.
    • SO U DIDNT HAD ANY DHCP CONFIGURATION IN YOUR IAP :smileyhappy: it's importent to ask the right question and share with us all the relevnat info - in order to get the right answer. :smileywink:
    and u should get an ip.
    please screenshot your gui - wired port config / dhcp . -if more assist needed.
    have a lovely weekend
    Me
