How to config LDAP authentication for WLAN Client
  • 1.  How to config LDAP authentication for WLAN Client
    Posted Mar 23, 2015 11:45 PM
    Hi everybody,
    Now I'm deploying 7 IAP 115 for my customer with Virtual Controller. But I have problem with LDAP Authentication. The Client can not connect to AP with Username/Password. I'm using AD Windows Server 2008. This is my configuration for SSID Test
    Can you help me for trouble it?
  • 2.  RE: How to config LDAP authentication for WLAN Client
    Posted Mar 23, 2015 11:51 PM
    You need to use a RADIUS server otherwise you'll need to install an EAP-GTC supplicant on most of your devices.
    Tim
