how to config VPN IP address pool
  • 1.  how to config VPN IP address pool
    Posted Sep 07, 2017 01:40 AM
    hello ~!
    I configured controller with Master/Local and i setting VPN service to Master.
    customers use RAP that is linked to the master controller.
    but customers want to use RAP that is linked to the local controller too.
    How can I set the VPN IP address pool on the local controller?
    Configure the same ip pool as the master controller?
    or different...
    I think 3 case
    1. Master (1.1.1.1 ~ 1.1.1.254) / Local (2.1.1.1~2.1.1.254)
    2. Master (1.1.1.1~1.1.1.150) / Local (1.1.1.151~1.1.1.254)
    3. Master (1.1.1.1~1.1.1.254) / Local (1.1.1.1~1.1.1.254)
    Thank you for read this.
    I appreciate any input you guys can provide.
  • 2.  RE: how to config VPN IP address pool
    Posted Sep 07, 2017 06:01 AM
    You can use the same pools as the master controller on the local, as long as the ip addresses are not routable.
  • 3.  RE: how to config VPN IP address pool
    Posted Jun 06, 2018 10:21 PM
    You can use the same pool or use a different pool.
    This is because you are deploying a virtual ip for vpn purposes.
