Hi!
As it seems to me the question was about snmpv3 protection with acl, so that not everyone could poll Switch, but only Monitoring Server and computers from the network of administrators.
Now I have such a task in front of me, but the only thing I managed to find is how to bind acl to snmp-server community, which is relevant for snmp v2a. https://www.arubanetworks.com/techdocs/AOS-CX/10.07/HTML/5200-7834/Content/Chp_SNMP/SNMP_cmds/snmp-ser-com-acs-lst.htm.
I have not found a similar document for AOS-CX version 10.12 or 10.13 either. Maybe in newer versions of AOS-CX there is a possibility to bind acl to snmpv3 settings.
__________________
Wadim
Original Message:
Sent: Jul 20, 2023 03:00 AM
Subject: How to Configuration SNMP V3 ACL on Aruba CX Switch
ACLs are supported on Aruba switches, the command to configure ACLs is "access-list":
6200(config)# access-list ip TEST_ACL
This would send you to an ACL configuration context and you can configure your ACL to restrict/allow the various networks or host you want. If your goal is to block SNMP you can configure something similar:
10 deny udp 10.10.1.1 eq snmp 10.10.1.100
20 deny udp 10.10.1.1 eq snmp-trap 10.10.1.100
30 permit any any any
Or is your goal to push configuration(ACL configuration) to your switch via SNMP?
Toni
Original Message:
Sent: Jul 19, 2023 01:12 AM
Hi Community,
Is anyone familiar with configuring SNMPv3 ACLs on Aruba CX? I attempted to apply an ACL on SNMP V3 but could not find the command. or does Aruba CX use other features instead of ACL?
