Hey Dude,
I had this issue after changing the network from 3 flat vlans to inter-vlan routing. Typically WOL uses udp protocol 7. You have to state which IP address the WOL broadcast packets will propagate from, for me the 2 servers in red in my server-farm send this out at 7:45 every morning. Please see my active config below.
Also remember that your server team will need to test the script, so once you added this config if they try & bounce the problem back to you then its not your problem.
vlan 1000
name "STF-SERVER-FARM"
tagged C15-C18,C21-C24
untagged C1,C5-C6,G1-G24,I1-I21,I24,K3-K12,K15-K23,Trk10
ip forward-protocol udp 10.0.0.17 7
ip forward-protocol udp 10.0.0.23 7
ip address 10.0.0.1 255.255.255.0
ip igmp
ip ospf 10.0.0.1 area 10.0.0.0
ip pim-sparse
ip-addr any
exit
protocol "IPv4,ARP,NetBEUI"
exit
