Cloud Managed Networks
  • 1.  How to configure a management VLAN
    Posted Oct 19, 2023 11:03 AM
    we have some 6100 and 6200F switches centrally managed by Aruba Central, and we would like to add them to our management VLAN so that nobody except authorized personnel can access them via HTTPS, via SSH or via any other way, but we're facing several issues. Do you have a best practice about that, please?
    What we tried:
    • We cannot use mgmt VRF on 6100 since it's not available
    • We gave static IP address to the switch at mgmt VLAN level, but we cannot set the gateway. We tried to do that at sttic route level, but it doesn't work
    • We tried to set the source interface, but still no effect
    Most of the times, the switch goes offline and we need to zeroing it and restart from scratch, so we must be missing something.
    Thank you if anyone of you has a clue!
    Bye,
    Luca
  • 2.  RE: How to configure a management VLAN
    Posted Oct 20, 2023 09:06 AM
    Howdy!
    I had the same/similar issue. With AOS-CX you need to put a ACL for the mgmt vlan on the default VRF. See below to see my configuration:
    loop-protect trap loop-detected
    ntp server 172.21.128.216
    ntp server pool.ntp.org minpoll 4 maxpoll 4 iburst
    ntp enable
    ssh server vrf default
    ssh server vrf mgmt
    vsf member 1
        type jl665a
        link 1 1/1/52
    vsf member 2
        type jl665a
        link 1 2/1/52
    access-list ip MGMT
        1 comment CONFIRM NUMBER TIER
        2 comment 10-30 PERMITS MGMT VLAN IP
        3 comment 40-60 DENYS ALL ELSE
        4 comment 990-1000 ALLOWS PING/ALL ELSE
        10 permit tcp 10.20.0.179/255.255.248.0 any eq ssh
        11 permit tcp 10.20.0.179/255.255.248.0 any eq https
        12 permit udp 10.20.0.179/255.255.248.0 any eq https
        20 permit udp 10.20.0.179/255.255.248.0 any eq snmp
        30 permit udp 10.20.0.179/255.255.248.0 any eq snmp-trap
        40 deny tcp any any eq ssh count
        41 deny udp any any eq https count
        42 deny tcp any any eq https count
        50 deny udp any any eq snmp count
        60 deny udp any any eq snmp-trap count
        990 comment ALLOW ALL
        1000 permit any any any
    apply access-list ip MGMT control-plane vrf default
    client track ip
    client device-fingerprint profile a
        lldp
        cdp
        dhcp
        http user-agent
    vlan 1
    vlan 2
        name VOICE_VLAN
    vlan 3
        name MGMT_VLAN
    vlan 100
        name WLAN_VLAN
    vlan 110
        name VPN_VLAN
    vlan 120
        name ENS_VLAN
    vlan 130
        name PA_VLAN
    vlan 140
        name GATE3_VLAN
    vlan 170
        name IMG_VLAN
    vlan 180
        name GATE_VLAN
    vlan 190
        name SAS_VLAN
    no spanning-tree
    interface mgmt
        no shutdown
        ip dhcp
    interface lag 1
        description UPLINK LAG
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed all
        lacp mode active
    interface 1/1/1
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
        client device-fingerprint apply-profile a
    interface 1/1/2
        no shutdown
        no routing
        vlan trunk native 1
        vlan trunk allowed 1-2
        loop-protect
    interface 1/1/3
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/4
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/5
        no shutdown
        no routing
        vlan access 120
        loop-protect
    interface 1/1/6
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/7
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/8
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/9
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/10
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/11
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/12
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/13
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/14
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/15
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/16
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/17
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/18
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/19
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/20
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/21
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/22
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/23
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/24
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/25
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/26
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/27
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/28
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/29
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/30
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/31
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/32
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/33
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/34
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/35
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/36
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/37
        no shutdown
        no routing
        vlan access 100
        loop-protect
    interface 1/1/38
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/39
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/40
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/41
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/42
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/43
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/44
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/45
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/46
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/47
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/48
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 1/1/49
        no shutdown
        lag 1
    interface 1/1/50
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/51
        no shutdown
        no routing
        vlan trunk native 1
    interface 1/1/52
        no shutdown
    interface 2/1/1
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/2
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/3
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/4
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/5
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/6
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/7
        no shutdown
        no routing
        vlan access 100
        loop-protect
    interface 2/1/8
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/9
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/10
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/11
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/12
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/13
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/14
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/15
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/16
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/17
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/18
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/19
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/20
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/21
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/22
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/23
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/24
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/25
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/26
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/27
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/28
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/29
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/30
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/31
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/32
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/33
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/34
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/35
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/36
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/37
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/38
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/39
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/40
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/41
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/42
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/43
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/44
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/45
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/46
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/47
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/48
        no shutdown
        no routing
        vlan trunk native 1
        loop-protect
    interface 2/1/49
        no shutdown
        lag 1
    interface 2/1/50
        no shutdown
        no routing
        vlan trunk native 1
    interface 2/1/51
        no shutdown
        no routing
        vlan trunk native 1
    interface 2/1/52
        no shutdown
    interface vlan 1
        ip address 172.21.148.251/17
        ip dhcp
            ! ip dhcp is ignored when static ip is configured
    interface vlan 3
        ip address 10.20.0.179/21
    snmp-server vrf default
    snmp-server trap-source 172.21.128.213 vrf default
    snmp-server trap snmp authentication coldstart warmstart vrf default
    snmp-server system-location OLII
    snmp-server system-contact ISC
    snmp-server community Public
    ip route 0.0.0.0/0 172.21.128.100
    ip dns server-address 172.21.128.50
    ip dns server-address 172.21.128.51
  • 3.  RE: How to configure a management VLAN
    Posted Oct 23, 2023 03:15 AM
    Hi MojoPBS,
    thanks for your reply. We've figured out how to assign a static IP only to mgmt VLAN, removing the one from VLAN 1: out error was that we were setting static routes at device level rather than at group level. The assignement at device level made the switch to become unreacheable when we disabled DHCP from VLAN 1, while assigning at group level made the job.
    Thank you,
    Luca
