How to configure Aruba AP 105 to capture packets and including the radiotap header.
  • 1.  How to configure Aruba AP 105 to capture packets and including the radiotap header.
    Posted Apr 14, 2014 02:45 PM
    Hi all,
    I have Aruba AP 105 and configured to capture raw packets. When i sniff packets using Wireshark or OmniPeak, the captured packtes doesn't contain radiotap header which is required to get the RSSI value. Can anybody help?
  • 2.  RE: How to configure Aruba AP 105 to capture packets and including the radiotap header.
    Posted Apr 23, 2014 05:43 PM
    If you capture with an AirPcap adapter you will see the radiotap info.
    When using packet capturing on the AP-105 and sending to OmniPeek, you should see noise floor and signal level in the packet info section of the decode:
