last person joined: 5 hours ago
How to configure captive portal
This thread has been viewed 35 times
  • 1.  How to configure captive portal
    Posted Aug 29, 2018 09:17 PM
    New to Aruba, where can I find the simplest of simple instruction on how to create a captive portal authentication profile.  I understand that you have an initial login and a post-login.  The initial sets up what you will have access to and the post will authenticate you.  But I get lost trying to get from initial to post.
  • 2.  RE: How to configure captive portal
    Posted Aug 30, 2018 06:11 AM
    The technote - Aruba Wireless and ClearPass Integration will cover the captive portal integration between AOS and ClearPass in the simplest form. You can refer the AOS captive portal configuration. The technote is also attached.
    You may also refer - Configuring Captive Portal Authentication Profiles.
  • 3.  RE: How to configure captive portal
