how to configure DHCP on redundant controllers ?
  • 1.  how to configure DHCP on redundant controllers ?
    Posted Dec 24, 2013 03:23 AM
    If I have two controllers in redundancy mode while all APs should get the IP address through DHCP on the controllers, I understand that DHCP server should be splitted between the controllers but what happens when one controller fails ?
    Lets say I have a class C subnet used for the APs, while there is atleast 200 APs connected to the controllers.
    By splitting DHCP each controller will provide 127 IP Addresses only, so if one of the controllers went down as soon as the APs restart and request a new IP address what would happen as the other controller is out of IPs ?
  • 2.  RE: how to configure DHCP on redundant controllers ?
    Posted Dec 24, 2013 05:09 AM
    They will not get an ip address.  Use an external DHCP server for the best results.
  • 3.  RE: how to configure DHCP on redundant controllers ?
  • 4.  RE: how to configure DHCP on redundant controllers ?
    Posted Dec 24, 2013 05:18 AM
    Thank you guys, I guess providing DHCP using the core switch would be a good option.
  • 5.  RE: how to configure DHCP on redundant controllers ?
    Posted Dec 24, 2013 12:36 PM
    I would strongly advise a server-based DHCP solution and not use network gear to provide those services. A majority of the DHCP solutions are free.
    Most DHCP features provided by network gear are meant for small deployments and do not scale well or provide HA capability.
