Wired Intelligent Edge
How to configure GUI access on aruba 2930F swicth?
This thread has been viewed 114 times
  • 1.  How to configure GUI access on aruba 2930F swicth?
    Posted Dec 11, 2018 05:59 AM
    Can any one please tell me how ro configure WEB GUI access on aruba 2930F swicth?
  • 2.  RE: How to configure GUI access on aruba 2930F swicth?
    MVP GURU
    Posted Dec 11, 2018 09:12 AM
    You only need to set a ip address to switch
    by default the HTTP is enable !
  • 3.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Dec 11, 2018 11:57 AM
    Greetings!
    As noted by alagoutte, plaintext HTTP Web UI access is enabled by default; an IP address must be configured on the switch and there must be basic IP reachability between the switch and the client.
    For secure Web access using TLS/SSL, a certificate must be installed on the switch before this capability can be enabled. To generate a self-signed certificate for testing purposes (not recommended for live production environments), follow the process documented in the Basic Operation Guide for ArubaOS-Switch. To generate a cryptographically-signed certificate using a trusted Certificate Authority (for production environments), use the procedure from the ArubaOS-Switch Hardening Guide.
  • 4.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Dec 17, 2018 02:29 PM
    Found a work around...
  • 5.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Feb 19, 2020 03:55 AM
    Can you help me ,
    I am able to login but it is in white screen
    Can you share some guide line to checks
    Debabarta
  • 6.  RE: How to configure GUI access on aruba 2930F swicth?
    MVP GURU
    Posted Feb 19, 2020 04:12 AM
    What browser do you are using ?
  • 7.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Feb 19, 2020 06:19 AM
    Hi
    Google Chrome-Version 80.0.3987.116 (Build officiel) (64 bits)
    Internet Explorer 11
    Please let me know for any additional information
  • 8.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Feb 19, 2020 09:39 AM
    XXXX-SW1# sh flash
    Image Size (bytes) Date Version
    Primary Image : 29335147 11/19/18 WC.16.07.0003
    Secondary Image : 29335147 11/19/18 WC.16.07.0003
    Boot ROM Version
    Primary Boot ROM Version : WC.16.01.0005
    Secondary Boot ROM Version : WC.16.01.0005
    Default Boot Image : Primary
    Default Boot ROM : Primary
  • 9.  RE: How to configure GUI access on aruba 2930F swicth?
    MVP GURU
    Posted Feb 20, 2020 04:26 AM
    What the web-management configuration ?
  • 10.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Feb 25, 2020 04:12 AM
    Hi
    No SSL only http
    password operator user-name "operator" plaintext "password"
    password manager user-name "admin" plaintext "password"
    IP address is configured in VLAN
    Getting the following error
  • 11.  RE: How to configure GUI access on aruba 2930F swicth?
    MVP GURU
    Posted Feb 25, 2020 04:29 AM
    do you have try to make erase config ? (and upgrade to last firmware ?)
  • 12.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Feb 25, 2020 04:36 AM
    Hi
    Thank you for your quick response .Will check and let you know
  • 13.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Dec 17, 2018 04:38 PM
    I was able to find a work around.  By default the http is enabled and if you have not configured any password before then it would automatically bring you to the admin level.
    But to be safe, first login to the CLI:
    conf t
    # http login will use admin or operator straight away no need for admin@system
    wr mem
    # OR
    save
     http://IP address of switch
     username: admin
     password: password
     click head icon and change to classic GUI
     Under Security > SSL > Certificate Requests
     Click Self-Signed Certificate
     Certificate Name: switch name or whatever you want to put
     Key Size: 2048
     Validity End Date: 2 years or whatever years you want to put > Click drop down arrow and choose 2021 then click date and ok
     Common Name CN: I just put the same name as Certificate Name
     Organizational Unit Name: Up to you
     Organization: up to you
     Locality: up to you
     State: up to you
     Country: up to you
     Click Install
     Security > SSL > Web Management > Change
     Tick enable
     SSL Port: 443
     Tick require SSL
     Click Save
     Test by logging in https://IP address of switch
  • 14.  RE: How to configure GUI access on aruba 2930F swicth?
    MVP GURU
    Posted Dec 22, 2018 12:45 PM
    You can also generate certificate using CLi
    crypto pki enroll-self-signed certificate-name .....
  • 15.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Dec 24, 2018 01:00 PM
    Yep, but there seems a lot of steps involved in the CLI and there is not a clear how to step by step commands on the internet... So I tried the workaround for now.
    Also, can the following commands be executed with a cut and paste in order to create a cli script or template for the self-signed Certificate?
    Ex:
    ArubaOS-Switch(config)# crypto pki enroll-self-signed certificate-name switch1 subject
    Enter Common Name(CN) : switch1
    Enter Org Unit(OU) : NetworkOperations
    Enter Org Name(O) : My Company
    Enter Locality(L) : CHI
    Enter State(ST) : IL
    Enter Country(C) :US
  • 16.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Mar 11, 2020 10:00 AM
    How can I access the switch ip address if its in another subnet than what I am on? I have a network that is only used as mgmt of devices. Firewall rules on my end permit m,e to access but the Aruba switch will only let me access management if I am in the same network. For example, I am on 10.10./16 network, Mgmt network is 172.16.30.x/24. I can fully access anything on 172 networks based on my rules on the third-party firewall, but the Aruba switch will not allow me to manage the switch from 172.16 networks unless I am on that network. Any suggestions? I've setup Ip authorizations, they seem to not be of any help. What in the Aruba is preventing this?
  • 17.  RE: How to configure GUI access on aruba 2930F swicth?
    Posted Mar 13, 2020 09:21 AM
    You need a routing to access IPs outside of your subnet.
    try "ip default-gateway X.X.X.X" on the switch.
