How to Configure Internet Exiting for a specific WLAN only
  • 1.  How to Configure Internet Exiting for a specific WLAN only
    Posted Apr 20, 2022 11:45 AM
    I would like to know how to configure the WLC to move the traffic from specific WLAN to the internet?
    Jorenilson Santos
  • 2.  RE: How to Configure Internet Exiting for a specific WLAN only
    Posted Apr 21, 2022 08:42 PM
    I am assuming you are referring to Instant APs. Generally IAPs are not the default gateway for any VLANs, so the IAPs can be configured to put an authenticated  wireless device in a particular VLAN and then its up to default gateway to take the routing decisions
