aruba switch 2930F interface vlan 10 =172.16.1.1
interface vlan 20 =172.16.2.1PC 1 172.16.1.10/24 (port 1 untagged vlan 10 )PC 2 172.16.2.10/24 (port 2 untagged vlan 20 )how to configure PC1 can ping to PC2 at cisco switch just need enable ip routing
That would do...
No acl's are configured i assume?
Can you ping your gateway?
is the firewall disabled on the client?
Is the mac-adress of the client learned on the interface and within the corrrect vlan?
1.no acl 2.pc ping to gateway OK!3.firewall disable
vlan 10 ping to vlan 20 fail !vlan 20 ping to vlan 10 fail !
