How to configure RADIUS authentication through CLI?
  • 1.  How to configure RADIUS authentication through CLI?
    Posted Sep 23, 2012 11:01 PM
    I try configuring Radius authentication for Instant 93 through CLI
    Config
    aaa radius-server radius01 host 10.0.1.251 key abcdefg
    aaa mgmt-authentication mode enable
    aaa mgmt-authentication auth-server radius01
    exit wr mem
    Buy it does not work. I check the configuration on WebUI but nothing changes. Would you pls tell me what's the right process
  • 2.  RE: How to configure RADIUS authentication through CLI?
    Posted Sep 24, 2012 03:07 AM
    I think command "wlan" for instant does not have "opmode" parameter. Is that means Radius server can not be configured for Instant
  • 3.  RE: How to configure RADIUS authentication through CLI?
    Posted Sep 24, 2012 11:55 AM
    Hi Jerry.
    Radius authentication is supported in Aruba Instant for captive portal, 802.1x and management auth. Configuration through CLI in Aruba Instant is not officially supported.
    Login to the UI, Goto PEF -> New and you should be able to create new radius server instant or you will be prompted to select or to create new Radius server instance in the SSID creation, this is depending on the type of SSID you are creating.
    CK
  • 4.  RE: How to configure RADIUS authentication through CLI?
    Posted Sep 24, 2012 10:29 PM
    Thanks Ckok, So Radius auth can only be configured on WebUI. Am I right?
  • 5.  RE: How to configure RADIUS authentication through CLI?
    Posted Sep 24, 2012 10:55 PM
    Yes Jerry.
  • 6.  RE: How to configure RADIUS authentication through CLI?
    Posted Sep 25, 2012 12:44 AM
    Many thanks
