Network Management
How to Configure SMTP settings on Airwave?
This thread has been viewed 26 times
  • 1.  How to Configure SMTP settings on Airwave?
    Posted Mar 01, 2015 03:02 PM
    How to configure SMTP on airwave so I can recive emails on erros and so on,
    I have read alot but didn't get where I add the email and password of email?
  • 2.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 01, 2015 04:55 PM
    on the AMP Setup page, you can configure the Email server there.
    You can also configure a relay server.
  • 3.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 02, 2015 12:18 PM
    hi
    to configure Airwave as a an SNMP Client  you go to
    AMP Setup > NMS  then you add a new SNMP server.
    Regards
  • 4.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 02, 2015 12:24 PM
    Not SNMP, SMTP... :)
  • 5.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 02, 2015 12:32 PM
    ok ,  i haven't   seen it  :)
  • 6.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 02, 2015 02:41 PM
    Dears I have Tried to add the line but gives this
    [root@localhost postfix]# main.cf: relayhost = [mail.airwave.com]
    -bash: main.cf:: command not found
  • 7.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 02, 2015 02:52 PM
    You can configure the relay host via the webUI.
    In order to do it via the CLI, you need to edit main.cf with an editor like 'vi'
  • 8.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 03, 2015 07:05 AM
    Thanks but how to do it with VI as it is my first time with Airwave and I need to know more about it
  • 9.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 03, 2015 02:27 PM
    Airwave uses postfix
    For general basic configuration go here
    http://www.postfix.org/BASIC_CONFIGURATION_README.html
    As for Airwave, goto AMP setup -> General
    You will see the following, choose yes to enable the mail server, then go create triggers
    If you want to use a relay, you can set an IP address and test as well.
    If you need to use something like a Gmail smtp server which requires authentication, then refer to the postfix help forums on how to configure that.
  • 10.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 03, 2015 02:34 PM
    have done this but it didn't work : for example :
    My configs: Use embaded system :yes
    to 123@gmail.com
    from 123@gmail.com
    send
    it said msg sent successfully
    but now msg apears at all
  • 11.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 03, 2015 02:37 PM
    Does your Airwave have internet access?
  • 12.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 03, 2015 03:26 PM
    Yes have internet access and DNS configured and all related issue
  • 13.  RE: How to Configure SMTP settings on Airwave?
    Posted Mar 03, 2015 04:43 PM
    I suggest opening a TAC case then.
    Have you looked through the mail logs on the server?
    tail -f /var/log/maillog
    To see if it gives you an idea why it doesn't send out.
