how to configure snmp on campus AP? Please advise ,thanks in advance
  • 1.  how to configure snmp on campus AP? Please advise ,thanks in advance
    Posted Dec 22, 2015 04:19 AM
    Hi , please advise how to configure snmp on campus AP? go to configuration/AP group/AP/AP system, right? We want to monitor all APs on a central monitoring station. Thanks in advance.
  • 2.  RE: how to configure snmp on campus AP? Please advise ,thanks in advance
    Posted Dec 22, 2015 04:37 AM
    You'll set it up in Configuration / SNMP. Here you can add your SNMP community, enable trap generation and add trap receiver details.
    Cheers
    James
  • 3.  RE: how to configure snmp on campus AP? Please advise ,thanks in advance
    Posted Dec 22, 2015 04:42 AM
    thanks for reply. but configuration/snmp  is used to configure snmp for the controller ,not the APs , right? We want to moniotr individual AP on another monitoring station.
  • 4.  RE: how to configure snmp on campus AP? Please advise ,thanks in advance
    Posted Dec 22, 2015 04:51 AM
    Your monitoring system will be able to pick up all the APs on the controller when setting up SNMP monitoring in the way I've described. :)
    Cheers
    James
  • 5.  RE: how to configure snmp on campus AP? Please advise ,thanks in advance
    Posted Dec 22, 2015 04:54 AM
    Thanks. let me try ...
  • 6.  RE: how to configure snmp on campus AP? Please advise ,thanks in advance
    Posted Dec 22, 2015 11:38 AM
    Any luck with that?
  • 7.  RE: how to configure snmp on campus AP? Please advise ,thanks in advance
    Posted Dec 22, 2015 05:02 PM
    The ap monitoring be snmp is done via the controller, as jrwhitehead mentioned.
    If you need an external monitoring tool to monitor the APs directly, at best you can do it via icmp.
