![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/c1f007e4e7454a14a0b072f14b3e1d39.png)
Anyone have any configuration guide about this kind of setup.
Both MC are managed by MM located in Building A. 1MC is building A with network 192.168.1.x and another in building B with network 172.16.1.x. I wish to build both MC into one cluster for failover purpose with different network.
May I know does this setup can be done? have any reference?
Should I enable L3 redundancy when intial setup the MC via CLI?
Still need setup VRRP? if yes, then what IP should used? if no, then we need set primary and secondary MC IP in "LMS" setting under AP group right?
what is the function for "Exclude VLANS" when assign individual MC into the cluster profile created. Does it fill in the VLANs which does not exist in both MC right?
