How to configure tunneled node with a controller cluster?
This thread has been viewed 21 times
  • 1.  How to configure tunneled node with a controller cluster?
    Posted Jan 13, 2022 12:03 PM
    Hello, I am upgrading my system and will now be using mobility controllers setup in a L3 cluster.  My Aruba switches  previously had tunneled node configured with a primary and backup controller.  How should I configure tunneled node now? Should I just use any cluster controller IP as primary controller IP
  • 2.  RE: How to configure tunneled node with a controller cluster?
    Posted Jan 14, 2022 09:55 AM
    Yes, just pick two IPs. I believe for port-based tunnel (=tunneled node), the switch will just pick the primary controller and fallback to the backup if there is an issue. With User Based Tunneling, the switch will follow the clustering for user traffic and distribute users over all controllers in the cluster.
    Check this video to see a switch with PBT to a gateway cluster.
  • 3.  RE: How to configure tunneled node with a controller cluster?
    Posted Jan 14, 2022 01:54 PM
    Thank you Herman :)
  • 4.  RE: How to configure tunneled node with a controller cluster?
    Posted Mar 11, 2022 06:51 AM
    The switch will follow the clustering for user traffic and distribute users over all controllers in the cluster.
    James Gross
