How to connect a iap 275 ?
  • 1.  How to connect a iap 275 ?
    Posted Nov 06, 2014 10:49 AM
    I needed help for install a iap 275.
    On a iap 275 we have 2 Network interfaces  WAN & LAN.
    It's is possible to know how install this product ? (Cabling)
    This is sufficient for work to use only Wan port or we have need to connect all port  wan and lan ?
    Ben.
  • 2.  RE: How to connect a iap 275 ?
    Posted Nov 06, 2014 10:51 AM
  • 3.  RE: How to connect a iap 275 ?
    Posted Nov 06, 2014 11:05 AM
    Ok for powering.
    The port LAN it's for what ? I have need or not ?
    Thans for your response.
    Ben.
  • 4.  RE: How to connect a iap 275 ?
    Posted Nov 06, 2014 11:14 AM
    No, you don't need that port unless you are providing wired access to a client device.
  • 5.  RE: How to connect a iap 275 ?
    Posted Nov 06, 2014 11:20 AM
    Thanks For Support .
    Ben
