how to connect ap365 in iap 207 cluster
  • 1.  how to connect ap365 in iap 207 cluster
    Posted Aug 23, 2017 07:17 AM
    I have 207 cluster with 5 access point,ineed to add outdoor ap 365 and i need to mesh that one.
    Aju Subair.
  • 2.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 23, 2017 10:20 AM
    The IAP365 does not share the same firmware as the 207, so you need to find the same level of code, but for the IAP365 and upgrade it offline before adding it to the IAP207 cluster.  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20375
  • 3.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 24, 2017 03:16 AM
    I am upgraded the firmware of ap365 but it's not adding to my 207 cluster, once I disconnect the 207 clusters from network its getting up.
    firmware details:-
    APFIRWARE
    IAP 2076.5.1.0-4.3.10_57768
    AP 3656.5.3.2
  • 4.  RE: how to connect ap365 in iap 207 cluster
    please give me a solution..
  • 5.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 24, 2017 03:22 AM
    You need to upgrade the 207 cluster so that it has the same version as the 365 - all devices need to be running the same version of firmware then they will join.
  • 6.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 24, 2017 03:51 AM
    when I am upgrading the firmware I am getting this reply,"upgrade cannot proceed because of another upgrade in progress".I restarted the cluster but result is same.
  • 7.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 24, 2017 03:55 AM
    Do you have all APs on the network when you see this message? try removing the 365 from the network and upgrade the 207 cluster on its own before adding the 365 back onto the network.
  • 8.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 24, 2017 04:03 AM
    yes, I removed ap365 from the network and restarted the AP 207.after that also same error.
  • 9.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 24, 2017 04:09 AM
    You will need to figure out which one is having an issue, go onto the command line of each AP in the cluster and run the command "show version" to see which version each AP is running. "show image version" will show you which images have been downloaded to the devices.
  • 10.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 24, 2017 04:19 AM
    now this cluster i connected only one IAP 207,i am trying to upgrade that ap firmware.now i reseted the ap and configured as new.still i am getting error when i upgrade,but error  changed "retrieve image failed please save the log in the pop up window".
  • 11.  RE: how to connect ap365 in iap 207 cluster
    MVP EXPERT
    Posted Aug 24, 2017 04:35 AM
    Are you able to provide the following?
    - Firmware file name which you are using for the IAP207
    - Output of the following CLI #show log upgrade
    Are you trying to update this via the automatic image download or are you manually uploading the image from the support site?
  • 12.  RE: how to connect ap365 in iap 207 cluster
    Posted Aug 24, 2017 05:26 AM
    I am very happy to announce you that I have done my experiment successfully.I downloaded the firmware version 6.5.2.0 for both series access points and manually upgraded the firmware. now both my access points working in the same cluster.
    This is the web site for downlode the firmware  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/25165/Default.aspx
    After upgrade Your login address will change to : https://setmeup.arubanetworks.com:4343/#home
    thanks all for the support..
  • 13.  RE: how to connect ap365 in iap 207 cluster
