Become a Member
Hi Everyone,
Am using controller aruba 7005 Os 8.3 but can not find folder connect to analytics and Location Engine (ALE).
Can you help me check?
Thank you.
https://www.arubanetworks.com/techdocs/ArubaOS_83x_Web_Help/Content/PDFs/ArubaOS%208.3.0.x%20CLI%20Reference%20Guide.pdf Check page 151
Hi Pavan,
I follow link but config ssh erro , can you help me check?
(attach file)
and Check page 151
Dear Pavan,
My controller: ArubaOS (MODEL: Aruba7005), Version 8.3.0.6. But when config ALE as your guide, it said:
(Aruba7005) [mynode] (config) #ale-configurationCommand not applicable for this platform
How can I fix this? Thank you very much.
Are you running on MD or its a standalone controller? I am able to run on my MM.
(DK-MM) [mynode] (config) #ale-configuration(DK-MM) ^[mynode] (config-submode)#
Did you get it solved ? Because I'm facing the same issue on my standalone controller (aos 8.5).
I'm afraid it is not possible to make ale configuration on a aos 8.x standalone controller ...
Can somebody confirm if we definitively need Mobility Master setup in order to configure ale ?
Are you able to run below command from AOS CLI
#show ale-configuration
There is no such limation, it should work for standalone aswell.
I checked it in House. Looks like the standalone is not giving the ALE tab. Only when we check from MM it is. I am checking with the controller guys on this. I will update the thread based on their response.
For GUI,
Configuration -> System -> More -> ALE
The below Airheads post might be helpful.
https://community.arubanetworks.com/t5/Forum-Fran%C3%A7ais/ALE-amp-AOS8-Notes-d-int%C3%A9gration/td-p/304619
I don't see button ALE? pls check image
Please choose Mobility Master folder (Top folder) and then select More. You will than be able to see ALE option.
Now I creat ssid using captive portal but can't access internet, you can help me check how to add roles from captive portal?
Thank you so much.
Open new thread this thread is for location query! are you creating roles in Clearpass or controller? If you are getting internet then check ACL rules for that role.
