Hi Team,
We plan to connect HP5900/HP5950 to Cisco5548 via ISL to verify FCoE.
Can someone suggest how to connect HP5900/HP5950 via ISL to Cisco 5548 to carry FCoE traffic? Is this a valid configuration?
Below are the switch and interface configuration details
FCoE Initiator (TE 1/0/15) ---- HP5900 (TE 1/0/48) ---- (Eth1/0/30) Cisco5548 ---- Target
HP5900 current configuration
lldp global enable
system-working-mode advance
fcoe-mode fcf
vlan 1004
fcoe enable vsan 1004
FCoE Initiator port connected to TE1/0/15
interface Ten-GigabitEthernet1/0/15
port link-mode bridge
port link-type trunk
port trunk permit vlan all
priority-flow-control auto
priority-flow-control no-drop dot1p 3
lldp tlv-enable dot1-tlv dcbx
qos trust dot1p
qos wrr af1 group 1 byte-count 1
qos wrr af2 group sp
qos wrr af3 group sp
qos wrr af4 group sp
qos wrr ef group sp
qos wrr cs6 group sp
qos wrr cs7 group sp
qos apply policy DCBX outbound
vfc15
interface Vfc15
port trunk vsan 1 1004
bind interface Ten-GigabitEthernet1/0/15
HPE5900 ISL connected to Cisco 5548: TE1/0/48
interface Ten-GigabitEthernet1/0/48
priority-flow-control enable
qos trust dot1p
interface Vfc48
fc mode e
bind interface Ten-GigabitEthernet1/0/48
display vsan 1004 port-member
VSAN 1004:
Access Ports:
Trunk Ports:
Vfc15 Vfc48
Cisco5548 ISL Port Connected to HP5900: Eth1/0/30
interface Ethernet1/30
switchport mode trunk
interface vfc30
bind interface Ethernet1/30
switchport mode E
switchport trunk allowed vsan 1004
no shutdown
#5950#ISL#5900#InterSwitchLink#fcoe
