How to connect Microsoft Azure to ClearPass as authentication source?
This thread has been viewed 52 times
  • 1.  How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Oct 31, 2017 05:07 AM
    I hope you guys can help me with the following: I'm trying to connect Microsoft Azure to ClearPass as an authentication source. I'm not talking about OnBoarding, but just user authentication for a wireless SSID.
    Anyone of you have experience with this? Unfortunately I cannot find any detailed configuration guide. Thanks in advance!
    Kind regards,
    Martijn
  • 2.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Oct 31, 2017 07:34 AM
    If you're trying to do 802.1X, you'd need to to Onboard. We have a full config guide: http://community.arubanetworks.com/t5/Security/ClearPass-Configuration-Guide-Onboard-Cloud-Identity-Providers/td-p/301657
  • 3.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Jul 24, 2018 04:03 AM
    I'm trying to do the same, but client are already onboarded via Microsoft Intune (user cert), so basicaly this should already work if I just add the trust CA cert in ClearPass? But what auth source do I need?
  • 4.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Nov 16, 2018 07:21 AM
    i would like to connect Master controller to Azure Active Directory and use it as a source of authentication, is that feasible? if yes how I can do that.
    regards,
    thanks,
  • 5.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Aug 06, 2019 08:23 PM
    I am currently working on something similar. Were you able to figure out how to get uers authenticated with AzureAD?
    TIA,
    Mani.
  • 6.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Aug 06, 2019 08:57 PM
    wasn't able to figure that out, i'm sorry !
  • 7.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Aug 06, 2019 09:02 PM
    Thanks for your reply!
    So are you still working on it left the project?
    ~Mani
  • 8.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Oct 02, 2019 10:58 AM
    Hi Tim!
    Azure onboarding guide is almost perfect. :) in page 23 is comment that very little configuration should make. What setting is included in Wireless - Azure AD - SAML settings? and Configuration profile Wireless_Aruba_Boston?
    Could you tell me more about this  ? What kind of ssid is should make? Is it hotspot that redirects clients to device_provisioning page or is it 802.1x authentication ? How this authentication goes from client to azure and back to wireless controller? Need help with this! Thank you!
  • 9.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Oct 02, 2019 01:58 PM
    The guide is not designed to cover core Onboard. At a high level, you'd at a link to the Onboard provisioning page to your guest captive portal. The 802.1X SSID would be EAP-TLS.
  • 10.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Oct 02, 2019 02:08 PM
    So onboard configuration should be done first? and this guidance is in youtube? That onboarding workshop is what i have to be done first?
    In wireless controller i have to do guest access wlan with guest portal that is onboarding portal? and after that is done, then is should match different service that use EAP-TLS authentication?
    If you have onboarding guide for this, it would be very nice and i think that i am not only who would like to see it? :)
  • 11.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Aug 26, 2019 06:12 AM
    I'm just following this thread, i'v got Azure Intune authentication needs as well.
    Ipads in our Azure AD that i need to authenticate with clearpass.
  • 12.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Aug 26, 2019 12:18 PM
    Authentication is handled by EAP-TLS.
    Authorization against Intune is handled by the Intune Extension.
  • 13.  RE: How to connect Microsoft Azure to ClearPass as authentication source?
    Posted Aug 27, 2019 02:48 AM
    thx.
    Had it the wrong way, of course eap-tls is the authentication.
