Can someone let me know where the serial port is? I just got two clearpass hardward applinaces and would like to do the inital config.
Many thanks!
I think you might want to do the initial configuration using the VGA port to a monitor and a USB-port to a keyboard.
Thanks for your help!
Do you happen to know default username password?
The username and password on the label is not working.
Cheers!
Are we talking about the webGUI now?
If you are on 6.6 or below, try admin/eTIPS123 (gui) and appadmin/eTIPS123 (cli)
It is 6.7.
I am talking about locahost login and WebGui.
There is a label on the appliance indicating username and password. I tried and did not work.
Sorry, appadmin eTIPS123 works.
Thanks!
