How to connect wifi if user is in different AD domain.
  • 1.  How to connect wifi if user is in different AD domain.
    Posted Dec 12, 2014 09:36 AM
    I have 2 different countries with 2 different setups n 2 different AD's. We are using certificate basses authentication via CPPM. Now what could be done to give seem less user experience if some visitors from one country to another.
    Let's say
    - both countries having same SSID name.
    -Both location controls r master.
    Will let u other info if required or ask queries.
    #ALE
  • 2.  RE: How to connect wifi if user is in different AD domain.
    Posted Dec 12, 2014 09:37 AM
    You can write a role map to check the common name of the certificate which usually contains the domain and then create new enforcement rules based on this data.
  • 3.  RE: How to connect wifi if user is in different AD domain.
    Posted Dec 12, 2014 10:45 AM
    Thanks for you comments.
    But as i am new to Aruba technology would you please share some document/PPT so that i can go though it and can understant it in better way.
    -Cheers!!
  • 4.  RE: How to connect wifi if user is in different AD domain.
    Posted Dec 12, 2014 11:15 AM
    There is no documentation on this specifc topic.
    Does the signing CA have the domain name in the DN of the cert?
  • 5.  RE: How to connect wifi if user is in different AD domain.
    Posted Dec 13, 2014 05:02 AM
    Yea, it is.
    Another thing, can 1 CPPM server be in 2 different AD groups?
