When I apply this command on controller it says "command is not supported for this ap model"
(Aruba 7005) [mynode] #ap redeploy controller-less ap-name ap1
How to convert this campus ap back to IAP?
Can you see on the label whether this is an AP-335 or an IAP-335?
Or type "show ap image version" to see what image the backup partition has:
https://community.arubanetworks.com/t5/Wireless-Access/Is-there-any-way-to-know-if-an-AP-is-CAP-or-IAP/td-p/299414
This is an IAP 335. First I played with IAP 335 in aruba cental and then converted to CAP to join to physical controller to know more about it. Now I want to convert back to IAP.
You should use the reset button in the back of the AP to revert back to Instant Mode. The ap redeploy controller-less is only supported on Universal APs.
