How to counter reset "Synchronize Database"
  • 1.  How to counter reset "Synchronize Database"
    Posted Jul 07, 2015 08:54 PM
    Hi,all
    Please tell me counter reset.
    I reset a counter and want to clear status of fail.
    I executed a command as follows.
    When one synchronization fails, an error is given.
    I want to know how to reset this counter.
    Switch > Synchronize Database
    <Abbreviation>-----------------
    1 synchronization have failed
    Periodic synchronization is enabled and runs every 30 minutes
    Synchronization doesn't include Captive Portal Custom data
    It does not appear in CLI manual.
  • 2.  RE: How to counter reset "Synchronize Database"
    Posted Jul 07, 2015 08:57 PM
    Unfortunately, there is no way to clear the counter.  The counter would only clear when the controller/switch reboots.
  • 3.  RE: How to counter reset "Synchronize Database"
    Posted Jul 07, 2015 09:33 PM
    Mr.Colin Joseph,
    Thank you for your response.
    I understood it.
    I try to reboot in the appropriate timing when a user does not have the influence.
    regarads,
    mika
