How to create a unique mail receipt template by receptionist ?
  • 1.  How to create a unique mail receipt template by receptionist ?
    Posted Apr 06, 2018 05:35 AM
    In CPPM, I created a multiple receptionists who can create a guest accounts.
    These receptionists have the possibility to send a receipt by mail to the guest after its creation.
    But the template used for this mail sending is the same for all the receptionists.
    So, I would like to create a unique email template by receptionnists but I did not find how to do this.
    Does anyone have an idea ?
  • 2.  RE: How to create a unique mail receipt template by receptionist ?
    Posted Apr 06, 2018 04:52 PM
    You can add the smtp_template_id and auto_send_smtp fields to the account creation form
    #AirheadsMobile
  • 3.  RE: How to create a unique mail receipt template by receptionist ?
    #AirheadsMobile
  • 4.  RE: How to create a unique mail receipt template by receptionist ?
    Posted Apr 09, 2018 11:55 AM
    Thank you for your response efisher214.
    I configured the two fields in the form.
    But, I cannot find the ID of the template that I want to use to send the email.
    Do you know how find this ID ?
  • 5.  RE: How to create a unique mail receipt template by receptionist ?
    Posted Apr 17, 2018 08:43 AM
    Hi guys,
  • 6.  RE: How to create a unique mail receipt template by receptionist ?
    Posted Jul 25, 2020 05:15 PM
    Hola!
    La solución que he encontrado tras toda una tarde probando:
    - Ir a Configuración-Recibos-Plantillas, pulsar en la plantilla que desees usar, pasar el ratón por encima de "Editar" y la URL que se visualiza en el navegador acaba en "id=NN". Ese número (NN) es el ID.
    - En Configuración-Páginas-Campos, crear el campo "smtp_template_id" de tipo STRING y Sortable text.
    - Añadir el campo anterior en el formulario create_user_x deseado como "HIDDEN field" (esto es muy importante) y darle el valor inicial NN (ID de la plantilla encontrado antes). Además, el formulario debe contener el campo "auto_send_smtp" de tipo checkbox.
    - Al dar de alta un usuario en Guest, marcar el check de envío de e-mail y debería llegar utilizando dicha plantilla.
    Un saludo.
