How to create Link Aggregation on S1500?
  • 1.  How to create Link Aggregation on S1500?
    Posted May 13, 2015 01:12 AM
    I have a server with 2 port network card. I would like to configure link aggregation on S1500 to have both ports on server to connect to S1500. Please advise how to configure link aggregation using web GUI.
  • 2.  RE: How to create Link Aggregation on S1500?
    Posted May 13, 2015 02:53 AM
    Upon login to S1500 UI, click on
     'Configuration'  ==>  'Ports' ==> 'Port-Channel'
    Two types of port-channel can be created
    1) Static
    2) LACP (dynamic)
     Add the target/connected gigabitethernet interfaces to the port-channel 'group'
    See the attached screen shots for reference:
  • 3.  RE: How to create Link Aggregation on S1500?
    Posted May 13, 2015 02:56 AM
    When you click on 'type', another window pops-up as below:
  • 4.  RE: How to create Link Aggregation on S1500?
    Posted May 13, 2015 03:36 AM
    What if I would like to apply VLAN onto the LACP group?
    Is it possible?
  • 5.  RE: How to create Link Aggregation on S1500?
    Posted May 13, 2015 06:57 AM
    Yes,
    VLAN application on ports is done using 'switching-profile'
    Create a new 'switching-profile' or use existing and then associate it to target port-channel
    See below:
