How to create more than vlan for management AP on Aruba 7210 Mobility Controllers ?
  • 1.  How to create more than vlan for management AP on Aruba 7210 Mobility Controllers ?
    Posted Dec 16, 2019 10:43 PM
    Dear all,
    Is now, I have working in building with 3 block A, B and C. I want create 3 vlan for manager access point in 3 block.
    Block A: 192.168.10.0/24
    Block B: 192.168.11.0/24
    Block C: 192.168.12.0/24
    But when I check on Controller I see only one Vlan can be use for managerment AP
     Everybody can help me how to create more than vlan for managerment AP in building.
    Thanks and regard,
  • 2.  RE: How to create more than vlan for management AP on Aruba 7210 Mobility Controllers ?
    MVP
    Posted Dec 17, 2019 01:41 AM
    You can choose 1 VLAN for the Wireless controller and you can still use all of your 3 blocks for the AP's. All you need to do is either provision the AP with the fixed IP address of the controller under AP Installation , Master Discovery, or you make sure aruba-master is well known everywhere in the network (DNS) with name pointing at the the IP Address of the Wireless Controller.
    (and make sure those 3 blocks of networks are capable on seeing each other)
