Training, Certification & Career
last person joined: 7 days ago
Get more information about the HPE Aruba Networking technical training and certification programs. Network with your colleagues to improve your career, and post job availability for network engineers within your organization.
How to create step by step Ap group, virtual ap, SSID manually?
  • 1.  How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 12, 2015 07:42 AM
    Hello to every one. I recentely took the ACMA (I am really happy). I have been studied by my self, However, I follow the lab book.
    I always provisioned "create" a new Network/SSID just following thw WLAN/LAN Wizard wich was pretty much easy to understand, but just for learned purposes, I want to the same thing as the wizard does but manually and by my self.
    I start to do it, but then I get lost :(
    Could you guys help me on it please?
  • 2.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 12, 2015 08:26 AM
    One thing you can do, is run through another wizard. Then when you complete the wizard look over the summary. you can open the GUI in another wizard the start working. When you get stumped you can check the summary from the wizard to get back on track.
  • 3.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 12, 2015 08:32 AM
    I will try it. One thing that I really get lost is on AAA.
    I'll post it here soon.
  • 4.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 12, 2015 08:35 AM
    Another method you can do is:
    Still do the wizard-
    At the summary click the link"Commands to be pushed" this will show you all of the configurations you will need to do. you can then copy this and drop it in a note somewhere and you can then do a step by step manual network configuration.
  • 5.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 12, 2015 09:28 AM
    I did not find the CLI command used, Look:
  • 6.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 12, 2015 10:06 AM
    OH!!
    I see your using a 200. The options I suggested were based off of later versions of code. Here is what I had mentioned. Ill send you the CLI list
  • 7.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 17, 2016 08:19 AM
    Can I create AP group from AP wizard?
  • 8.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 17, 2016 10:13 AM
    Yes, see below
  • 9.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 17, 2016 10:16 AM
    Is it WLAN wizard or AP wizard
  • 10.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 17, 2016 10:21 AM
    I see now you asked about the AP wizard.
    Still a yes, see below
  • 11.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 17, 2016 10:22 AM
    Thanks, Jamie
  • 12.  RE: How to create step by step Ap group, virtual ap, SSID manually?
    Posted Nov 12, 2015 11:43 AM
    Oh!
    Now I can see, I didn't realize it so far. Well, I will try to do it in one controller running 6.4 firmware and check what would be the step by step on CLI. However, with your help, I was able to configured what  wanna to.
    Thank you so much for your help Jamie. :)
