How to debug RAP-2WG issues?
  • 1.  How to debug RAP-2WG issues?
    Posted Mar 20, 2012 12:41 PM
    i'm new to Aruba and currently on a test-environment. Today i've tried to access our Mobility Controller (which is connected to the internet by our router having DNATs for Port 500 and 4500) using a RAP2 from my homeoffice. Connectivity seems ok, but the web-gui of the RAP tells about an IKE Error.
    How can i find the source of the problem? Where can i look at? There must be some kind of log, but where?
  • 2.  RE: How to debug RAP-2WG issues?
    Posted Mar 20, 2012 12:46 PM
    @Oliver.geisen@kreisbote.de wrote:
    Start with the IKE Error.  What is it?
  • 3.  RE: How to debug RAP-2WG issues?
    Posted Mar 20, 2012 12:56 PM
    A common IKE error which is occurs when the RAP is not added to the RAP whitelist is RC_ERROR_IKE_XAUTH_AUTHORIZATION_FAILED. If this is your error message then make sure you have added the RAP to the RAP whilelist on the master controller.
    Sathya
  • 4.  RE: How to debug RAP-2WG issues?
    Posted Mar 21, 2012 03:02 AM
  • 5.  RE: How to debug RAP-2WG issues?
    Posted Mar 21, 2012 07:26 AM
    Is the rap in the rap white list on the controller ?
  • 6.  RE: How to debug RAP-2WG issues?
    Posted Mar 21, 2012 07:45 AM
    Currently not. I will add him and try again this evening. Reporting tomorrow.
    Thanks for now!
  • 7.  RE: How to debug RAP-2WG issues?
    Posted Mar 21, 2012 07:47 AM
    Okay, did you also create an IPSec pool for your aps, as well?
  • 8.  RE: How to debug RAP-2WG issues?
    Posted Mar 21, 2012 05:39 PM
    So, i one step further. After adding the RAP using the Controller-Wizard it cames up on my home site and lights the WLAN LED. But it still don't transmitt any SSIDs. In the controller i can see that it seems ok (no longer mismatched or down).
    I think i was missing some setup. What is this IPSec pool thing you mention?
  • 9.  RE: How to debug RAP-2WG issues?
    Posted Mar 21, 2012 06:10 PM
    Every RAP that authenticates successfully to  the controller requires a valid inner IP address for the IPsec tunnel. This inner IP address is issued from the address pool that is configured in the VPN services.
    Also on CLI type
    show ap debug received-config ap-name <name of AP> to check that the RAP has received all the required configurations such those related to the VAP and radio settings.
    Sathya
  • 10.  RE: How to debug RAP-2WG issues?
    Posted Mar 22, 2012 05:53 AM
    Oh, yes, i see. I already had this. My RAP gets 172.29.241.7, which is an inner IP address of a VLAN, specially created for VPN-Services (RAP and VIA). The VLAN is reachable via the controllers interface in the local network. Routing is pointed to that interface.
    I can also PING the RAP from our coorporate network.
  • 11.  RE: How to debug RAP-2WG issues?
    Posted Mar 22, 2012 06:24 AM
    On the commandline of the controller, type "show ap bss-table" to see if your RAP is broadcasting anything, and what...
  • 12.  RE: How to debug RAP-2WG issues?
    Posted Mar 22, 2012 04:15 PM
    It don't seem so. Here is the console output of your suggested command:
    (the RAP in question has the HWADDR 00:24:6c:cd:46:e5)
    (Aruba3200) # show ap bss-table
    fm (forward mode): T-Tunnel, S-Split, D-Decrypt Tunnel, B-Bridge (s-standard, p-persistent, b-backup, a-always)
    Aruba AP BSS Table
    bss                ess               s/p  ip            phy   type  ch/EIRP/max-EIRP  cur-cl  ap name            in-t(s)  tot-t        mtu   acl-state  acl  fm
    d8:c7:c8:83:3e:70  Kreisbote-Gast    1/0  172.29.2.244  a-HT  ap    136-/20.5/20.5    0       d8:c7:c8:c0:33:e6  0        11h:35m:21s  1500  -          6    T
    d8:c7:c8:c5:22:b1  Kreisbote-VoIP    1/0  172.29.2.250  g-HT  ap    11/20/20          0       d8:c7:c8:c4:52:2b  0        11h:35m:23s  1500  -          49   T
    d8:c7:c8:83:3e:71  Kreisbote-VoIP    1/0  172.29.2.244  a-HT  ap    136-/20.5/20.5    0       d8:c7:c8:c0:33:e6  0        11h:35m:21s  1500  -          49   T
    d8:c7:c8:a1:2d:20  Kreisbote-Gast    1/0  172.29.3.244  g-HT  ap    6/20/20           0       d8:c7:c8:c2:12:d2  0        11h:35m:22s  1500  -          6    T
    d8:c7:c8:c5:22:b2  Kreisbote-Intern  1/0  172.29.2.250  g-HT  ap    11/20/20          0       d8:c7:c8:c4:52:2b  0        11h:35m:23s  1500  -          1    T
    d8:c7:c8:83:3e:72  Kreisbote-Intern  1/0  172.29.2.244  a-HT  ap    136-/20.5/20.5    0       d8:c7:c8:c0:33:e6  0        11h:35m:20s  1500  -          1    T
    d8:c7:c8:a1:2d:21  Kreisbote-VoIP    1/0  172.29.3.244  g-HT  ap    6/20/20           0       d8:c7:c8:c2:12:d2  0        11h:35m:22s  1500  -          49   T
    d8:c7:c8:83:42:50  Kreisbote-Gast    1/0  172.29.2.243  a-HT  ap    52+/20.5/20.5     0       d8:c7:c8:c0:34:24  0        11h:35m:21s  1500  -          6    T
    d8:c7:c8:a1:2d:22  Kreisbote-Intern  1/0  172.29.3.244  g-HT  ap    6/20/20           0       d8:c7:c8:c2:12:d2  0        11h:35m:22s  1500  -          1    T
    d8:c7:c8:83:42:51  Kreisbote-VoIP    1/0  172.29.2.243  a-HT  ap    52+/20.5/20.5     0       d8:c7:c8:c0:34:24  0        11h:35m:21s  1500  -          49   T
    d8:c7:c8:83:42:52  Kreisbote-Intern  1/0  172.29.2.243  a-HT  ap    52+/20.5/20.5     0       d8:c7:c8:c0:34:24  0        11h:35m:21s  1500  -          1    T
    d8:c7:c8:83:3e:60  Kreisbote-Gast    1/2  172.29.2.244  g-HT  ap    1/15.5/15.5       0       d8:c7:c8:c0:33:e6  0        11h:35m:20s  1500  -          6    T
    d8:c7:c8:c5:22:b8  Kreisbote-Gast    1/0  172.29.2.250  a-HT  ap    116+/25/25        0       d8:c7:c8:c4:52:2b  0        11h:35m:23s  1500  -          6    T
    d8:c7:c8:83:3e:61  Kreisbote-VoIP    1/2  172.29.2.244  g-HT  ap    1/15.5/15.5       0       d8:c7:c8:c0:33:e6  0        11h:35m:20s  1500  -          49   T
    d8:c7:c8:c5:22:b9  Kreisbote-VoIP    1/0  172.29.2.250  a-HT  ap    116+/25/25        0       d8:c7:c8:c4:52:2b  0        11h:35m:23s  1500  -          49   T
    d8:c7:c8:83:3e:62  Kreisbote-Intern  1/2  172.29.2.244  g-HT  ap    1/15.5/15.5       0       d8:c7:c8:c0:33:e6  0        11h:35m:20s  1500  -          1    T
    d8:c7:c8:a1:29:90  Kreisbote-Gast    1/0  172.29.3.243  g-HT  ap    11/20/20          0       d8:c7:c8:c2:12:99  0        11h:35m:22s  1500  -          6    T
    d8:c7:c8:a1:2d:28  Kreisbote-Gast    1/0  172.29.3.244  a-HT  ap    108+/25/25        0       d8:c7:c8:c2:12:d2  0        11h:35m:22s  1500  -          6    T
    d8:c7:c8:c5:22:ba  Kreisbote-Intern  1/0  172.29.2.250  a-HT  ap    116+/25/25        0       d8:c7:c8:c4:52:2b  0        11h:35m:23s  1500  -          1    T
    d8:c7:c8:83:42:40  Kreisbote-Gast    1/0  172.29.2.243  g-HT  ap    1/15.5/15.5       0       d8:c7:c8:c0:34:24  0        11h:35m:21s  1500  -          6    T
    d8:c7:c8:a1:29:91  Kreisbote-VoIP    1/0  172.29.3.243  g-HT  ap    11/20/20          1       d8:c7:c8:c2:12:99  0        11h:35m:22s  1500  -          49   T
    d8:c7:c8:a1:2d:29  Kreisbote-VoIP    1/0  172.29.3.244  a-HT  ap    108+/25/25        0       d8:c7:c8:c2:12:d2  0        11h:35m:22s  1500  -          49   T
    d8:c7:c8:83:42:41  Kreisbote-VoIP    1/0  172.29.2.243  g-HT  ap    1/15.5/15.5       0       d8:c7:c8:c0:34:24  0        11h:35m:21s  1500  -          49   T
    d8:c7:c8:a1:29:92  Kreisbote-Intern  1/0  172.29.3.243  g-HT  ap    11/20/20          1       d8:c7:c8:c2:12:99  0        11h:35m:22s  1500  -          1    T
    d8:c7:c8:a1:2d:2a  Kreisbote-Intern  1/0  172.29.3.244  a-HT  ap    108+/25/25        0       d8:c7:c8:c2:12:d2  0        11h:35m:22s  1500  -          1    T
    d8:c7:c8:c5:20:f0  Kreisbote-Gast    1/0  172.29.3.247  g-HT  ap    1/20/20           0       d8:c7:c8:c4:52:0f  0        11h:35m:22s  1500  -          6    T
    d8:c7:c8:83:42:42  Kreisbote-Intern  1/0  172.29.2.243  g-HT  ap    1/15.5/15.5       0       d8:c7:c8:c0:34:24  0        11h:35m:21s  1500  -          1    T
    d8:c7:c8:c5:20:f1  Kreisbote-VoIP    1/0  172.29.3.247  g-HT  ap    1/20/20           0       d8:c7:c8:c4:52:0f  0        11h:35m:22s  1500  -          49   T
    d8:c7:c8:c5:20:f2  Kreisbote-Intern  1/0  172.29.3.247  g-HT  ap    1/20/20           0       d8:c7:c8:c4:52:0f  0        11h:35m:22s  1500  -          1    T
    d8:c7:c8:a1:29:98  Kreisbote-Gast    1/0  172.29.3.243  a-HT  ap    120-/25/25        0       d8:c7:c8:c2:12:99  0        11h:35m:22s  1500  -          6    T
    d8:c7:c8:a1:29:99  Kreisbote-VoIP    1/0  172.29.3.243  a-HT  ap    120-/25/25        0       d8:c7:c8:c2:12:99  0        11h:35m:22s  1500  -          49   T
    d8:c7:c8:a1:29:9a  Kreisbote-Intern  1/0  172.29.3.243  a-HT  ap    120-/25/25        0       d8:c7:c8:c2:12:99  0        11h:35m:22s  1500  -          1    T
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Aruba AP BSS Table
    d8:c7:c8:c5:20:f8  Kreisbote-Gast    1/0  172.29.3.247  a-HT  ap    40-/23/23         0       d8:c7:c8:c4:52:0f  0        11h:35m:28s  1500  -          6    T
    d8:c7:c8:c5:20:f9  Kreisbote-VoIP    1/0  172.29.3.247  a-HT  ap    40-/23/23         0       d8:c7:c8:c4:52:0f  0        11h:35m:28s  1500  -          49   T
    d8:c7:c8:c5:20:fa  Kreisbote-Intern  1/0  172.29.3.247  a-HT  ap    40-/23/23         0       d8:c7:c8:c4:52:0f  0        11h:35m:28s  1500  -          1    T
    d8:c7:c8:c5:22:b0  Kreisbote-Gast    1/0  172.29.2.250  g-HT  ap    11/20/20          1       d8:c7:c8:c4:52:2b  0        11h:35m:29s  1500  -          6    T
    00:24:6c:cd:46:e5  N/A               1/3  172.29.241.8  e1    N/A   N/A               N/A     aruba-rap1         0        15h:9m:49s   1200  N/A        1    T
    Num APs:37
    Num Associations:3
  • 13.  RE: How to debug RAP-2WG issues?
    Posted Mar 28, 2012 08:22 AM
    We could'nt get this to work. So we created another AP-group, put the RAP into it, and voilá SSIDs comming up... something very strange is going on here.
  • 14.  RE: How to debug RAP-2WG issues?
    Posted Mar 28, 2012 12:45 PM
    Good to hear that the RAP is working but when it was not working did you try this command and see whether it got all its config.
    You can also use these commands to see if the IPSec tunnel was formed properly
    (rc1-sunnyvale-3600) #show crypto ipsec sa
    (rc1-sunnyvale-3600) #show crypto isakmp sa
    To see whether a AP is active use the command
    (rc1-sunnyvale-3600) #show ap active
    Sathya
  • 15.  RE: How to debug RAP-2WG issues?
    Posted Jan 28, 2017 12:19 PM
    Please help on below error  in Aruba rap 2Wg device.
  • 16.  RE: How to debug RAP-2WG issues?
    Posted Jan 28, 2017 02:14 PM
    That means it cannot reach the controller.
  • 17.  RE: How to debug RAP-2WG issues?
    Posted Jan 28, 2017 03:22 PM
    Dear sir,
    Thnks for the reply.
    How can it solved.
    Connectivity is below in detail.
    Leased line(192.168.10.1) conected to fortinet firewall. From firewall already allowed the ip 172.30.30.100 it is the master controller ip. From firewall is connected to hp switch.from hp switch to aruba 2wg device. 2 year it was working fine suddenly network was down on last saturday.
    then reset the router many times.and tried to configure e0 to switch and e1 to laptop.while configuring the device at stage 3/4 getting the attached error.
    kindly solve this
    While configuring
  • 18.  RE: How to debug RAP-2WG issues?
    Posted Jan 28, 2017 03:25 PM
    You need to find out if anything has changed with your network configuration when it went down.  You should be allowing udp 4500 to your controller from the outside.  Find out if that was changed, somehow.
  • 19.  RE: How to debug RAP-2WG issues?
    Posted Jan 28, 2017 03:38 PM
    Can i have your whatsapp number sir.
  • 20.  RE: How to debug RAP-2WG issues?
    Posted Jan 28, 2017 03:52 PM
    Dear sir,
    Please, it would great thankful to you if i get your whtsapp number .
    Need your expertise help on this issue.
    Jose
  • 21.  RE: How to debug RAP-2WG issues?
    Posted Jan 28, 2017 05:08 PM
    I don't have a whatsapp number, but on the controller, you can type "show datapath session table <public ip address of rap>" to see if the traffic is coming into the controller.
    Do this, while you are provisioning the AP to see if traffic is coming into the controller...
  • 22.  RE: How to debug RAP-2WG issues?
    Posted Jan 29, 2017 02:55 AM
    Dear sir
    I have one doubt. If i take this aruba device in another branch location (172.16.59.1) network and try the device to configure. And if it gets configured successfull and bring back the device to orignal location (192.168.10.1) will it work?
  • 23.  RE: How to debug RAP-2WG issues?
    Posted Jan 29, 2017 06:42 AM
    It should work everywhere, unless you have UDP 4500 blocked somewhere in the path...
  • 24.  RE: How to debug RAP-2WG issues?
    Posted Jan 29, 2017 07:54 AM
    Can i get the customer support number so that they can solve the issue.
    Location is from india
  • 25.  RE: How to debug RAP-2WG issues?
  • 26.  RE: How to debug RAP-2WG issues?
    Posted Jan 30, 2017 12:49 AM
    Hi sir,
    Please check and advice.
  • 27.  RE: How to debug RAP-2WG issues?
    Posted Jan 30, 2017 06:06 AM
    Your tests might not be conclusive.  The devices between your RAP and the controller might have ICMP and traceroute turned off.
    Do you have a firewall in front of the controller?
  • 28.  RE: How to debug RAP-2WG issues?
    Posted Jan 29, 2017 09:24 AM
    Dear  colin,
    If i get your number it would more thankful to you.
    jose jesuratnam
  • 29.  RE: How to debug RAP-2WG issues?
    Posted May 21, 2017 11:57 AM
    Dear sir,
    Please help me on this.
    we have a aruba device rap3 WN.
    Mac id is already whitelisted  in Master aruba device. but am getting retrieve image failure error.ARUBA rap 3 wn.jpg
  • 30.  RE: How to debug RAP-2WG issues?
    Posted May 21, 2017 03:37 PM
    Is there a log in the popup Window?
    What version of ArubaOS are you running?
  • 31.  RE: How to debug RAP-2WG issues?
    Posted May 27, 2017 03:50 PM
    Dear Sir,
    Please, here is attached the pdf file configuration taken from my rap 3 device. kinldy check and help.
    jose jesuratnam
    Attachment(s)
    pdf
    ARUBA RAP3WN Console.pdf   193 KB 1 version
