How to decode ARUBA RTLS packets
  • 1.  How to decode ARUBA RTLS packets
    Posted Jun 02, 2015 11:50 AM
    Experts!
    Sorry for disturbing, we want build our own location system from RTLS packets collected from ARUBA AP, but found there is little information about this from internet and it's diffcult to decode the information in RTLS packets. Now we could only decode the packets header. Do you have experience in this and could shed some light on this:
    For example, below information is the whole packet contents:
    00:14:fc:c5:01:00:00:5c:9c:1c:12:ce:8f:06:00:00:00:02:00:00:00:13:fc:c3:02:00:00:1c:9c:1c:12:ce:8f:06:00:00:9c:1c:12:68:f0:62:5d:0a:06:c4:02:01:9c:1c:12:68:f0:60:9c:1c:12:68:f0:62:00:00:00:01:00:13:fc:c4:02:00:00:1c:9c:1c:12:ce:8f:06:00:00:08:57:00:19:0c:5f:5d:00:06:d9:01:01:9c:1c:12:68:f0:60:9c:1c:12:68:f0:64:00:00:00:01:eb:de:e8:ab:ce:05:d6:f2:5a:ea:9a:2c:e8:ea:5e:f8:11:62:c0:38
    We could decode the packet header:
    bytes[0-1]   00:14                      Message type: AR_COMPOUND_MESSAGE_REPORT
    bytes[2-3]   fc:c5                               Message id:  fc:c5
    bytes[3-4]   01:00                      Major vision: 01 Minor Vision :00
    bytes[5-6]   00:5c                      Data Length
    bytes[7-12]  9c:1c:12:ce:8f:06            AP MAC address
    bytes[13-14] 00:00                             Padding
    But from offset 14bytes we couldn't found any clue to decode it:
    Attachment(s)
    zip
    rtls-2.pcap.zip   2 KB 1 version
  • 2.  RE: How to decode ARUBA RTLS packets
    Posted Jun 02, 2015 02:20 PM
    I suspect Aruba will consider the contents to be somewhat proprietary.
    I've been looking at the API for data from the Aruba ALE server - the ALE server collects the Aruba proprietary data from iAP, Controller and Airwave, interprets it and transmits it in a well defined format.
    Now that I type this, I'm thinking that studying the ALE API document, you might be able to interpret the raw RTLS data, but might be easier to use ALE to translate.
  • 3.  RE: How to decode ARUBA RTLS packets
    Posted May 09, 2018 11:08 AM
    I too am VERY interested in this.  We have to build an ALE-like sniffer and RTLS seems like the right way to go.  I'm anxiously looking for anyone/help/advice that has done or tried this...
  • 4.  RE: How to decode ARUBA RTLS packets
    Posted May 09, 2018 05:13 PM
    Hi Chris,
    check this: https://github.com/lukaskaplan/aruba-rtls
    It is my testing script, maybe it can be good source of information for start...
    Lukas
  • 5.  RE: How to decode ARUBA RTLS packets
    Posted May 09, 2018 05:23 PM
    Thank you so much!
    I'm still new to Aruba "stuff". So, I can setup my IAP's (or controller)'s
    RTLS to point to this type of listener, yes?
    What I dont understand is that the setup interface on the IAP or controller
    wants some "key". What key is that? How do I get it? I think the docs say
    it is the "secret" key and not sure where I get that for these devices...
    Chris Stakutis
    978 764 3488
  • 6.  RE: How to decode ARUBA RTLS packets
    Posted May 10, 2018 04:06 AM
    You can write there what you want, but it has to be same on both sides (controller and RTLS script).
  • 7.  RE: How to decode ARUBA RTLS packets
    Posted May 10, 2018 06:22 AM
    Really? Hmmm. So, just to clarify...
    When I configure the RTLS page on the IAS or Controller, in the 'secret key
    field' I invent some value, then, in the RTLS receiving code I use the same
    value and all will be happy?
    BTW, thank you for your help!
    Chris Stakutis
    978 764 3488
    *Alexa "My Life" service for aging/elderly*
    http://www.wholehealthplustechnology.com
    http://www.concordsoftwareandexecutiveconsulting.com/
  • 8.  RE: How to decode ARUBA RTLS packets
    Posted Sep 22, 2015 10:02 PM
    Have you solved the problem? Can I get your solution?Or you can give me an example about the AR_ACK packet??  Thank you.
  • 9.  RE: How to decode ARUBA RTLS packets
    Posted Nov 14, 2017 08:39 AM
    AR_ACK is easy.
    1) You will recieve AR_AP_NOTIFICATION, it is 36 byte. First 16 bytes are Header and last 20 bytes are "checksum". There is no payload.
    2) You have to get this header, change first 2 bytes from 0x0015 to 0x0010.
    3) Create new checksum of new header (HMAC sha1).
    4) Send new header with new checksum (no payload) - 36 bytes back to controller.
    It is all
