Is there any way to schedule a deletion of all guest accounts at the end of each calendar month?
Thanks.
From where, ClearPass? To my knowledge you'll need to do this under Cluster Wide Parameters and the Expired guest accounts cleanup interval?
https://www.arubanetworks.com/techdocs/ClearPass/6.6/PolicyManager/Content/CPPM_UserGuide/Admin/ServerConfig_clusterwideparams.htm#Cleanup
You can't specify a calendar month date to delete, but you can specify the number of days after expiry that the cleanup occurs.
Another way is to leverage ClearPass APIs and use a scheduled script that runs monthly to delete the guest accounts based on any criteria that you want..
