Wired Intelligent Edge
last person joined: 4 hours ago
How to delete an acceslist on a 5406 with running KB 16.02.0013?
  • 1.  How to delete an acceslist on a 5406 with running KB 16.02.0013?
    Posted May 30, 2018 05:02 AM
    How can I delete an accesslist with the irregular sign "." in the name?
  • 2.  RE: How to delete an acceslist on a 5406 with running KB 16.02.0013?
    Posted Jun 01, 2018 02:39 PM
    Greetings!
    From our initial testing, it does not appear that the CLI will allow you to remove the ACL as the invalid character validation check prevents the command from working.  We are investigating the issue in the lab; do you know what command was originally used to create the ACL with the "." in the name?
  • 3.  RE: How to delete an acceslist on a 5406 with running KB 16.02.0013?
    Posted Jun 07, 2018 04:27 AM
    Greetings
    If you configure the ACL in the VLAN context the invalid character validation check doesn't work and the ACL will be created.
  • 4.  RE: How to delete an acceslist on a 5406 with running KB 16.02.0013?
    Posted Jun 08, 2018 01:31 PM
    I'm filing a report with engineering on this particular issue so they can fix it; in the meantime, during your next maintenance window when you have an opportunity to reboot the switch, you can copy the startup configuration off the switch, rename or remove the offending ACLs, then copy the fixed configuration back onto the switch and reboot.
