How to delete an offline AP name in a MM-MD solution
This thread has been viewed 23 times
  • 1.  How to delete an offline AP name in a MM-MD solution
    Posted Oct 28, 2019 11:28 AM
    I can't find any option on MM webGUI to delete an offline AP name. Maybe it can be deleted via CLI mode, can anyone give a clue on how to do it? Thank you
  • 2.  RE: How to delete an offline AP name in a MM-MD solution
    MVP EXPERT
    Posted Oct 28, 2019 11:38 AM
    To delete stale APs:
    1. Issue the clear gap-db stale-ap apname <ap-name> lms lms-ip <lms-ip>command to delete a stale entry on a particular managed device.
    --OR --
    2. Issue the clear gap-db ap-name <apname> command to delete the GAP entries for the AP on the Mobility Master and the current LMS of the AP.
    NOTE: The first step will delete stale entries individually from the old managed devices and the second step will remove stale entries for the Mobility Master and the current LMS.
  • 3.  RE: How to delete an offline AP name in a MM-MD solution
    Posted Oct 28, 2019 01:30 PM
    Hi Craig,
    Fixed, thank you so much.
  • 4.  RE: How to delete an offline AP name in a MM-MD solution
    Posted Oct 28, 2019 07:48 PM
    On the MM dashboard, Infrastructure, if you have a down AP in the list there is a 'Delete access point' trash bin icon if you hover over each line. Does this do the same thing?
