How to determine IAP part number?
This thread has been viewed 21 times
  • 1.  How to determine IAP part number?
    Posted Mar 06, 2020 06:18 PM
    Hello. I have a number of IAP 315s. I can retrieve the model number with show version, but I'm having trouble finding the part number. I tried putting the serial number in the HPE warranty check, but it wouldn't tell me there either. Short of climbing a ladder to pull one down, how can I determine the part number of the device? For reference, you can see there are a few IAP 315 part numbers in the document I've linked below. I realize it's likely mine is either JW813A or JW813ACM since I'm US based, but is there a way to tell for sure via CLI or GUI maybe?
    https://www.arubanetworks.com/assets/ds/DS_AP310Series.pdf
  • 2.  RE: How to determine IAP part number?
    Posted Mar 06, 2020 06:58 PM
    for US based IAP-315 here are the part numbers
    JW813A             Aruba Instant IAP-315 (US)
    JW814A             Aruba Instant IAP-315 (US) TAA version
  • 3.  RE: How to determine IAP part number?
    Posted Mar 10, 2021 10:45 AM
    Does anybody knows what is the Canadian part number ?
    I see US, JP et RW.
    US is obvious and Jp is Japan i guess.
    Tx
    Marc Desj
  • 4.  RE: How to determine IAP part number?
    Posted Mar 11, 2021 03:44 AM
    US=USA & Territories; JP=Japan; IL=Israel, EG=Egypt
    Canada is part of Rest-of-World = RW
    When you order, you should only be able to order an AP or controller for your own 'regulatory domain'. You should not even have an option to order a -US/-JP from Canada.
